ArcGIS Server Banner
ST_Centroid
ST_Centroid
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_Centroid takes a polygon or multipolygon and returns the point that is in the center of the geometry's envelope. That means that the centroid point is halfway between the geometry's minimum and maximum X and Y extents.
Syntax
Oracle
sde.st_centroid (pl1 sde.st_geometry)
sde.st_centroid (mpl1 sde.st_geometry)
PostgreSQL
st_centroid (pl1 st_geometry)
st_centroid (mpl1 st_geometry)
Return type
ST_Point
Example
The city GIS technician wants to display the building footprint multipolygons as single points in a building density graphic. The building footprints are stored in the bfp table that was created and populated with the following statements.
Oracle
CREATE TABLE bfp (
building_id integer,
footprint sde.st_geometry);
INSERT INTO bfp VALUES (
1,
sde.st_polygon ('polygon ((0 0, 0 10, 10 10, 10 0, 0 0))', 0)
2,
sde.st_polygon ('polygon ((20 0, 30 20, 40 0, 20 0))', 0)
3,
sde.st_polygon ('polygon ((20 30, 25 35, 30 30, 20 30))', 0)
PostgreSQL
CREATE TABLE bfp (
footprint st_geometry);
1,
2,
3,
The ST_Centroid function returns the centroid of each building footprint multipolygon. The ST_AsText function converts each centroid point into a text representation recognized by the application.
Oracle
SELECT building_id,
sde.st_astext (sde.st_centroid (footprint)) Centroid
FROM bfp;
BUILDING_ID                   Centroid
   1                     POINT  (5.00000000 5.00000000)
   2                     POINT  (30.00000000 10.00000000)
   3                     POINT  (25.00000000 32.50000000)
PostgreSQL
SELECT building_id,
st_astext (st_centroid (footprint)) AS centroid
FROM bfp;
building_id                  centroid
   1                     POINT  (5 5)
   2                     POINT  (30 10)
   3                     POINT  (25 33)
See Also
  • An overview of SQL functions used with ST_Geometry types
