ArcGIS Server Banner
ST_Contains
ST_Contains
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_Contains takes two geometry objects and returns 1 (Oracle) or t (PostgreSQL) if the first object completely contains the second; otherwise, it returns 0 (Oracle) or f (PostgreSQL).
Syntax
Oracle
sde.st_contains (g1 sde.st_geometry, g2 sde.st_geometry)
PostgreSQL
st_contains (g1 st_geometry, g2 st_geometry)
Return type
Boolean
Example
In the example below, two tables are created. One, bfp, contains a city's building footprints, while the other, lots, contains its lots. The city engineer wants to ensure that all building footprints are completely inside their lots.
In both tables, the multipolygon data type stores the geometry of the building footprints and the lots. The database designer selected multipolygons for both features because lots can be separated by natural features, such as a river, and building footprints can comprise several buildings.
Oracle
CREATE TABLE bfp (building_id integer,
footprint sde.st_geometry);
CREATE TABLE lots (lot_id integer,
lot sde.st_geometry);
INSERT INTO bfp (building_id, footprint) VALUES (
1,
sde.st_polygon ('polygon ((0 0, 0 10, 10 10, 10 0, 0 0))', 0)
2,
sde.st_polygon ('polygon ((20 0, 20 10, 30 10, 30 0, 20 0))', 0)
3,
sde.st_polygon ('polygon ((40 0, 40 10, 50 10, 50 0, 40 0))', 0)
INSERT INTO lots (lot_id, lot) VALUES (
1,
sde.st_polygon ('polygon ((-1 -1, -1 11, 11 11, 11 -1, -1 -1))', 0)
2,
sde.st_polygon ('polygon ((19 -1, 19 11, 29 9, 31 -1, 19 -1))', 0)
3,
sde.st_polygon ('polygon ((39 -1, 39 11, 51 11, 51 -1, 39 -1))', 0)
PostgreSQL
footprint st_geometry);
lot st_geometry);
1,
2,
3,
1,
2,
3,
The city engineer selects the buildings that are not completely contained within one lot.
Oracle
SELECT UNIQUE (building_id)
FROM bfp, lots
WHERE sde.st_intersects (lot, footprint) = 1
AND sde.st_contains (lot, footprint) = 0;
BUILDING_ID
PostgreSQL
SELECT DISTINCT (building_id)
FROM bfp, lots
WHERE st_intersects (lot, footprint) = 't'
AND st_contains (lot, footprint) = 'f';
building_id
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial relationships
