ArcGIS Server Banner
ST_Entity
ST_Entity
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for Oracle only
Definition
ST_Entity returns the spatial entity type of a geometry. The spatial entity type is the value stored in the entity member field of the ST_Geometry object.
Syntax
sde.st_entity (g1 sde.st_geometry)
Return type
Number
Example
CREATE TABLE sample_geometries (id integer, geometry sde.st_geometry);
INSERT INTO sample_geometries (id, geometry) VALUES (
1901,
sde.st_geometry ('point (1 2)', 0)
INSERT INTO sample_geometries (id, geometry VALUES (
1902,
sde.st_geometry ('linestring (33 2, 34 3, 35 6)', 0)
1903,
sde.st_geometry ('polygon ((3 3, 4 6, 5 3, 3 3))', 0)
SELECT sde.st_entity (geometry) entity, UPPER (sde.st_geometrytype (geometry))
TYPE
FROM sample_geometries;
ENTITY  TYPE
    1    ST_POINT
    4    ST_LINESTRING
    8    ST_POLYGON
See Also
  • An overview of SQL functions used with ST_Geometry types
