ArcGIS Server Banner
ST_EnvIntersects
ST_EnvIntersects
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for Oracle only
Definition
ST_EnvIntersects returns 1 (TRUE) if the envelopes of two geometries intersect; otherwise, it returns 0 (FALSE).
Syntax
sde.st_envintersects (g1 sde.st_geometry, g2 sde.st_geometry)
sde.st_envintersects (g1 sde.st_geometry, minx number, miny number, maxx number, maxy number)
Return type
Integer (Boolean)
Example
This example searches for a parcel that has an envelope intersected by the defined polygon.
CREATE TABLE sample_geoms (id integer, geometry sde.st_geometry);
INSERT INTO sample_geoms VALUES (
1,
sde.st_geometry ('linestring (10 10, 50 50)', 0)
2,
sde.st_geometry ('linestring (10 20, 50 60)', 0)
This SELECT statement compares the envelopes of two geometries and the geometries themselves to see if the features or the envelopes intersect.
SELECT a.id, b.id, sde.st_intersects (a.geometry, b.geometry) Intersects, sde.st_envintersects (a.geometry, b.geometry) Envelope_Intersects
FROM sample_geoms a, sample_geoms b
WHERE a.id = 1
AND b.id=2;
ID      ID      INTERSECTS   ENVELOPE_INTERSECTS
1       2       0            1
You could also specify an envelope to detect which features, if any, fall inside the envelope you pass in with the WHERE clause of the SELECT statement.
SELECT id
FROM sample_geoms
WHERE sde.st_envintersects(geometry, 5, 5, 60, 65) = 1;
ID
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial relationships
