ArcGIS Server Banner
ST_Equalsrs
ST_Equalsrs
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for PostgreSQL only
Definition
ST_Equalsrs checks to find if two spatial reference systems of two different feature classes are identical or not. If the spatial reference systems are identical, t (TRUE) is returned. If the spatial reference systems are not identical, ST_Equalsrs returns f (FALSE).
Syntax
st_equalsrs (srid1 integer, srid2 integer)
Return type
Integer
Example
In this example, the spatial reference IDs (SRID) of different feature classes are discovered, then ST_Equalsrs is used to see if the SRIDs represent the same spatial reference system or not.
SELECT srid, table_name
FROM sde_layers
WHERE table_name = 'transmains' OR table_name = 'streets';
srid table_name
2 streets
6 transmains
Now, use ST_Equalsrs to determine if the spatial reference systems identified by these two SRIDs are the same.
SELECT st_equalsrs(2,6) ;
 st_equalsrs
(1 row)
See Also
  • An overview of SQL functions used with ST_Geometry types
