ArcGIS Server Banner
ST_ExteriorRing
ST_ExteriorRing
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_ExteriorRing returns the exterior ring of a polygon as a linestring.
Syntax
Oracle
sde.st_exteriorring (pl1 sde.st_geometry)
PostgreSQL
st_exteriorring (pl1 st_geometry)
Return type
ST_LineString
Example
An ornithologist, wanting to study the bird population on several South Seas islands, knows that the feeding zone of the bird species she is interested in is restricted to the shoreline. As part of her calculation of the island's carrying capacity, the ornithologist requires the islands' perimeters. Some of the islands are so large they have several ponds on them. However, the shoreline of the ponds is inhabited exclusively by another more aggressive bird species. Therefore, the ornithologist requires the perimeter of only the exterior ring of the islands.
The ID and name columns of the islands table identify each island, while the land polygon column stores the island's geometry.
Oracle
CREATE TABLE islands (id integer,
name varchar(32),
land sde.st_geometry);
INSERT INTO islands VALUES (
1,
'Bear',
sde.st_polygon ('polygon ((40 120, 90 120, 90 150, 40 150, 40 120),(50 130, 60 130, 60 140, 50 140, 50 130),
(70 130, 80 130, 80 140, 70 140, 70 130))', 0)
2,
'Johnson',
sde.st_polygon ('polygon ((10 10, 50 10, 10 30, 10 10))', 0)
PostgreSQL
name varchar(32),
land st_geometry);
1,
'Bear',
2,
'Johnson',
The ST_ExteriorRing function extracts the exterior ring from each island polygon as a linestring. The length of the linestring is calculated by the ST_Length function. The linestring lengths are summarized by the SUM function.
Oracle
SELECT SUM (sde.st_length (sde.st_exteriorring (land)))
FROM islands;
SUM(ST_LENGTH(ST_EXTERIORRING(LAND)))
                            264.72136
PostgreSQL
SELECT SUM (st_length (st_exteriorring (land)))
FROM islands;
sum
264.721359549996
The exterior rings of the islands represent the ecological interface each island shares with the sea.
Some of the islands have ponds, which are represented by the interior rings of the polygons.
See Also
  • An overview of SQL functions used with ST_Geometry types
