ArcGIS Server Banner
ST_GeometryType
ST_GeometryType
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_GeometryType takes an ST_Geometry object and returns its geometry type as a string.
Syntax
Oracle
sde.st_geometrytype (g1 sde.st_geometry)
PostgreSQL
st_geometrytype (g1 st_geometry)
Return type
Varchar(32) containing one of the following
Example
The geometrytype_test table contains the g1 geometry column.
The INSERT statements insert each geometry subclass into the g1 column.
Oracle
CREATE TABLE geometrytype_test (g1 sde.st_geometry);
INSERT INTO geometrytype_test VALUES (
sde.st_geomfromtext ('point (10.02 20.01)', 0)
sde.st_geomfromtext ('linestring (10.01 20.01, 10.01 30.01, 10.01 40.01)', 0)
sde.st_geomfromtext ('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
19.15 33.94, 10.02 20.01))', 0)
sde.st_geomfromtext ('multipoint (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
sde.st_geomfromtext ('multilinestring ((10.02 20.01, 10.32 23.98,
11.92 25.64), (9.55 23.75, 15.36 30.11))', 0)
sde.st_geomfromtext ('multipolygon (((10.02 20.01, 11.92 35.64, 25.02 34.15,
19.15 33.94, 10.02 20.01)), ((51.71 21.73, 73.36 27.04, 71.52 32.87, 52.43 31.90,51.71 21.73)))', 0)
PostgreSQL
CREATE TABLE geometrytype_test (g1 st_geometry);
st_geometry ('point (10.02 20.01)', 0)
st_geometry ('linestring (10.01 20.01, 10.01 30.01, 10.01 40.01)', 0)
st_geometry ('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
st_geometry ('multipoint (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
st_geometry ('multilinestring ((10.02 20.01, 10.32 23.98,
st_geometry ('multipolygon (((10.02 20.01, 11.92 35.64, 25.02 34.15,
The query lists the geometry type of each subclass stored in the g1 geometry column.
Oracle
SELECT UPPER (sde.st_geometrytype (g1)) Geometry_type
FROM geometrytype_test;
Geometry_type
ST_POINT
ST_LINESTRING
ST_POLYGON
ST_MULTIPOINT
ST_MULTILINESTRING
ST_MULTIPOLYGON
PostgreSQL
SELECT (st_geometrytype (g1)) AS Geometry_type
Geometry_type
ST_POINT
ST_LINESTRING
ST_POLYGON
ST_MULTIPOINT
ST_MULTILINESTRING
ST_MULTIPOLYGON
See Also
  • An overview of SQL functions used with ST_Geometry types
