ArcGIS Server Banner
ST_GeomFromText
ST_GeomFromText
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for Oracle only; for spatial type for PostgreSQL, use ST_Geometry.
Definition
ST_GeomFromText takes a well-known text representation and a spatial reference ID and returns a geometry object.
Syntax
sde.st_geomfromtext (wkt clob, srid integer)
Return type
ST_Geometry
Example
The geometry_test table contains the integer gid column, which uniquely identifies each row, and the g1 column, which stores the geometry.
CREATE TABLE geometry_test (gid smallint unique, g1 sde.st_geometry);
The INSERT statements insert the data into the gid and g1 columns of the geometry_test table. The ST_GeomFromText function converts the text representation of each geometry into its corresponding instantiable subclass. The SELECT statement at the end is done to ensure data was inserted into the g1 column.
INSERT INTO geometry_test VALUES (
1,
sde.st_geomfromtext ('point (10.02 20.01)', 0)
2,
sde.st_geomfromtext('linestring (10.01 20.01, 10.01 30.01, 10.01 40.01)', 0)
3,
sde.st_geomfromtext('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
19.15 33.94, 10.02 20.01))', 0)
4,
sde.st_geomfromtext('multipoint (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
5,
sde.st_geomfromtext ('multilinestring ((10.02 20.01, 10.32 23.98,
11.92 25.64), (9.55 23.75, 15.36 30.11))', 0)
6,
sde.st_geomfromtext ('multipolygon (((10.02 20.01, 11.92 35.64,
25.02 34.15, 19.15 33.94, 10.02 20.01), (51.71 21.73, 73.36 27.04,
71.52 32.87, 52.43 31.90, 51.71 21.73)))', 0)
SELECT sde.st_astext(g1)
FROM geometry_test;
See Also
  • An overview of SQL functions used with ST_Geometry types
