ArcGIS Server Banner
ST_IsMeasured
ST_IsMeasured
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for Oracle only
Definition
ST_IsMeasured takes a geometry as an input parameter and returns 1 if the given geometry has measures or 0 if it does not.
Syntax
sde.st_ismeasured (g1 sde.st_geometry)
Return type
Integer (Boolean)
Example
CREATE TABLE ismeas_test (id integer, geometry sde.st_geometry);
INSERT INTO ismeas_test VALUES (
1902,
sde.st_geometry ('polygon ((40 120, 90 120, 90 150, 40 150, 40 120))', 0)
1903,
sde.st_geometry ('multipoint m(10 10 5, 50 10 6, 10 30 8)' , 0)
1904,
sde.st_geometry ('linestring z(10 10 166, 20 10 168)', 0)
1905,
sde.st_geometry ('point zm(10 10 16 30)', 0)
SELECT id, sde.st_ismeasured (geometry) Has_Meas
FROM ismeas_test;
        ID   Has_Meas
      1902          0
      1903          1
      1904          0
      1905          1
See Also
  • An overview of SQL functions used with ST_Geometry types
