ArcGIS Server Banner
ST_LineFromShape
ST_LineFromShape
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for PostgreSQL only
Definition
ST_LineFromShape takes an ESRI shape and a spatial reference ID and returns an ST_LineString.
Syntax
st_linefromshape (esri_shape bytea, srid integer)
Return type
ST_LineString
Example
Create the lshape table with two geometry columns—one an st_linestring, the other a bytea—and a unique ID.
CREATE TABLE lshape (id integer unique, geom1 st_linestring, geom2 bytea);
Add records to the lshape table.
INSERT INTO lshape (id, geom1) VALUES (
100,
st_linestring ('linestring (850 250, 850 850)', 0)
101,
st_linestring ('linestring (33 2, 34 3, 35 6)', 0)
Convert geom1 value to bytea.
UPDATE lshape
SET geom2 = st_asshape (geom1)
WHERE id = 100;
UPDATE lshape
WHERE id = 101;
Return the linestrings as text.
SELECT id, st_astext (st_linefromshape (geom2)) AS LINE
FROM lshape;
id 	line
100	LINESTRING ( 850 250, 850 850)
101 LINESTRING ( 33 2, 34 3, 35 6)
See Also
  • An overview of SQL functions used with ST_Geometry types
