ArcGIS Server Banner
ST_MaxZ
ST_MaxZ
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_MaxZ takes a geometry as an input parameter and returns its maximum z-coordinate.
Syntax
Oracle
sde.st_maxz (g1 sde.st_geometry)
PostgreSQL
st_maxz (g1 st_geometry)
Return type
Number
Example
Oracle
CREATE TABLE maxz_test (id integer, geometry sde.st_geometry);
INSERT INTO maxz_test VALUES (
1901,
sde.st_polygon ('polygon zm((110 120 20 3, 110 140 22 3, 120 130 26 4, 110 120 20 3))', 0)
1902,
sde.st_polygon ('polygon zm((0 0 40 7, 0 4 35 9, 5 4 32 12, 5 0 31 5, 0 0 40 7))', 0)
SELECT id, sde.st_maxz (geometry) Max_Z
FROM maxz_test;
        ID      MAX_Z
      1901         26
      1902         40
PostgreSQL
CREATE TABLE maxz_test (id integer, geometry st_geometry);
1901,
1902,
SELECT id, st_maxz (geometry) AS Max_Z
FROM maxz_test;
        id      max_z
      1901         26
      1902         40
See Also
  • An overview of SQL functions used with ST_Geometry types
