ArcGIS Server Banner
ST_MinX
ST_MinX
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_MinX takes a geometry as an input parameter and returns its minimum x-coordinate.
Syntax
Oracle
sde.st_minx (g1 sde.st_geometry)
PostgreSQL
st_minx (g1 st_geometry)
Return type
Number
Example
Oracle
CREATE TABLE minx_test (id integer, geometry sde.st_geometry);
INSERT INTO minx_test VALUES (
1901,
sde.st_polygon ('polygon zm((110 120 20 3, 110 140 22 3, 120 130 26 4, 110 120 20 3))', 0)
1902,
sde.st_polygon ('polygon zm((0 0 40 7, 0 4 35 9, 5 4 32 12, 5 0 31 5, 0 0 40 7))', 0)
SELECT id, sde.st_minx (geometry) MinX
FROM minx_test;
        ID       MINX
      1901        110
      1902          0
PostgreSQL
CREATE TABLE minx_test (id integer, geometry st_geometry);
1901,
1902,
SELECT id, st_minx (geometry) AS MinX
FROM minx_test;
        id       minx
      1901        110
      1902          0
See Also
  • An overview of SQL functions used with ST_Geometry types
