ArcGIS Server Banner
ST_MPointFromShape
ST_MPointFromShape
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for PostgreSQL only
Definition
ST_MPointFromShape takes an ESRI multipoint shape and a spatial reference ID and returns an ST_MultiPoint.
Syntax
st_mpointfromshape (esri_shape bytea, srid integer)
Return type
ST_MultiPoint
Example
In this example, the multipoint is stored with ID = 10 in the geometry column of the mpoints table, then the shape column is updated with a shape representation (using the ST_AsShape function). Finally, the ST_MPointFromShape function is used to return the multipoint from the shape column. The x- and y-coordinates for this geometry are (44, 14) (35, 16) (24, 13). The mpoints table has a geometry column, where the multipoint is stored, and a shape column, where the multipoint's ESRI shape representation is stored.
CREATE TABLE mpoints (id integer, geometry st_geometry, shape bytea);
INSERT INTO mpoints (id, geometry) VALUES (
10,
st_multipoint ('multipoint (4 14, 35 16, 24 13)', 0)
UPDATE mpoints
SET shape = st_asshape (geometry)
WHERE id = 10;
In the following SELECT statement, the ST_MPointFromShape function is used to retrieve the multipoint from the shape column.
SELECT id, st_astext (st_mpointFromShape (shape)) AS "MULTI_POINT"
FROM mpoints
WHERE id = 10;
id 	  MULTIPOINT
10         MULTIPOINT (4 14, 35 16, 24 13)
See Also
  • An overview of SQL functions used with ST_Geometry types
