ArcGIS Server Banner
ST_OrderingEquals
ST_OrderingEquals
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_OrderingEquals compares two geometries and returns 1 (Oracle) or t (PostgreSQL) if the geometries are equal and the coordinates are in the same order; otherwise, it returns 0 (Oracle) or f (PostgreSQL).
Syntax
Oracle
sde.st_orderingequals (g1 sde.st_geometry, g2 sde.st_geometry)
PostgreSQL
st_orderingequals (g1 st_geometry, g2 st_geometry)
Return type
Integer (Boolean)
Example
The following CREATE TABLE statement creates the LINESTRING_TEST table, which has two ST_LineString columns, ln1 and ln2.
Oracle
CREATE TABLE linestring_test (
lid integer,
ln1 sde.st_linestring,
ln2 sde.st_geometry);
PostgreSQL
lid integer,
ln1 st_linestring,
ln2 st_geometry);
The following INSERT statement inserts two ST_LineString values into ln1 and ln2 that are equal and have the same coordinate ordering.
Oracle
INSERT INTO linestring_test VALUES (
1,
sde.st_linefromtext ('linestring (10.01 20.02, 21.50 12.10)', 0),
PostgreSQL
1,
st_linestring ('linestring (10.01 20.02, 21.50 12.10)', 0),
The following SELECT statement and corresponding result set shows how the ST_Equals function returns 1 (TRUE) regardless of the order of the coordinates. The ST_OrderingEquals function returns 0 (FALSE) if the geometries are not both equal and have the same coordinate ordering.
Oracle
SELECT lid, sde.st_equals (ln1, ln2) Equals, sde.st_orderingequals (ln1, ln2) OrderingEquals
FROM linestring_test;
lid Equals     OrderingEquals
1   1          1
PostgreSQL
SELECT lid, st_equals (ln1, ln2) AS Equals, st_orderingequals (ln1, ln2) AS OrderingEquals
lid equals     orderingequals
1   t          t
See Also
  • An overview of SQL functions used with ST_Geometry types
