ArcGIS Server Banner
ST_PointFromShape
ST_PointFromShape
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for PostgreSQL only
Definition
ST_PointFromShape takes an ESRI point shape and a spatial reference ID and returns a point.
Syntax
st_pointfromshape (esri_shape bytea, srid integer)
Return type
ST_Point
Example
In this example, the points are stored in the geometry column of the pts table, and the shape column is updated with their shape representations (using the ST_AsShape function). Finally, the ST_PointFromShape function is used to return the points from the shape column. The pts table has a geometry column, where the points are stored, and a shape column, where the points' shape representations are stored.
CREATE TABLE pts (id integer, geometry st_point, shape bytea);
INSERT INTO pts (id, geometry) VALUES (
10,
st_point ('point (44 14)', 0)
11,
st_point ('point (24 13)', 0)
UPDATE pts
SET shape = st_asshape (geometry)
WHERE id = 10;
UPDATE pts
WHERE id = 11;
In the following SELECT statement, the ST_PointFromShape function is used to retrieve the points from the shape column.
SELECT id, st_astext (st_pointfromshape(shape, 0)) AS points
FROM pts;
id	points
10	POINT (44 14)
11	POINT (24 13)
See Also
  • An overview of SQL functions used with ST_Geometry types
