ArcGIS Server Banner
ST_PointN
ST_PointN
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_PointN takes an ST_LineString and an integer index and returns a point that is the nth vertex in the ST_LineString's path.
Syntax
Oracle
sde.st_pointn (ln1 sde.st_linestring, index integer)
PostgreSQL
st_pointn (ln1 st_linestring, index integer)
Return type
ST_Point
Example
The pointn_test table is created with the gid column, which uniquely identifies each row, and the ln1 ST_LineString column. The INSERT statements insert two linestring values. The first linestring doesn't have z-coordinates or measures, while the second linestring has both.
Oracle
CREATE TABLE pointn_test (gid integer, ln1 sde.st_geometry);
INSERT INTO pointn_test VALUES (
1,
sde.st_linefromtext ('linestring (10.02 20.01, 23.73 21.92, 30.10 40.23)', 0)
2,
sde.st_linefromtext ('linestring zm(10.02 20.01 5.0 7.0, 23.73 21.92 6.5 7.1, 30.10 40.23 6.9 7.2)', 0)
PostgreSQL
CREATE TABLE pointn_test (gid integer, ln1 st_geometry);
1,
st_linestring ('linestring (10.02 20.01, 23.73 21.92, 30.10 40.23)', 0)
2,
st_linestring ('linestring zm(10.02 20.01 5.0 7.0, 23.73 21.92 6.5 7.1, 30.10 40.23 6.9 7.2)', 0)
The query lists the gid column and the second vertex of each linestring. The first row results in an ST_Point without a z-coordinate or measure, while the second row results in an ST_Point with a z-coordinate and a measure. The ST_PointN function will also include a z-coordinate or measure value if they exist in the source linestring.
Oracle
SELECT gid, sde.st_astext (sde.st_pointn (ln1, 2)) The_2ndvertex
FROM pointn_test;
GID The_2ndvertex
1   POINT (23.73 21.92)
2   POINT ZM (23.73 21.92 6.5 7.1)
PostgreSQL
SELECT gid, st_astext (st_pointn (ln1, 2)) AS The_2ndvertex
FROM pointn_test;
gid the_2ndvertex
See Also
  • An overview of SQL functions used with ST_Geometry types
