ArcGIS Server Banner
ST_PolyFromShape
ST_PolyFromShape
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
NOTE: Spatial type for PostgreSQL only
Definition
ST_PolyFromShape takes an ESRI multipolygon shape and a spatial reference ID and returns a polygon.
Syntax
st_polyfromshape (esri_shape bytea, srid integer)
Return type
ST_Polygon
Example
This example illustrates how ST_PolyFromShape can be used to create a polygon from an ESRI shape representation. In this example, the polygon is stored in the geometry column of the polys table, then the shape column is updated with its ESRI shape representation (using the ST_AsShape function). Finally, the ST_PolyFromShape function is used to return the multipolygon from the shape column. The x- and y-coordinates for this geometry are (50, 20) (50, 40) (70, 30). The polys table has a geometry column, where the polygon is stored; a shape column, where the polygon's ESRI shape representation is stored; and an id column to uniquely identify each record.
CREATE TABLE polys (id integer unique, geometry st_geometry, shape bytea);
INSERT INTO polys VALUES (
111,
st_polygon ('polygon  ((10.01 20.03, 10.52 40.11, 30.29 41.56,
31.78 10.74, 10.01 20.03))', 0)
UPDATE polys
SET shape = st_asshape (geometry)
WHERE id = 111;
SELECT id, st_astext (st_polyfromshape (shape, 0)) AS polygon
FROM polys;
id    polygon
111    POLYGON (10.01000000 20.03000000, 31.78000000 10.74000000, 30.29000000 41.56000000, 10.52000000 40.11000000, 10.01000000 20.03000000)
See Also
  • An overview of SQL functions used with ST_Geometry types
