ArcGIS Server Banner
ST_Relate
ST_Relate
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_Relate compares two geometries and returns 1 (Oracle) or t (PostgreSQL) if the geometries meet the conditions specified by the DE-9IM pattern matrix string; otherwise, 0 (Oracle) or f (PostgreSQL) is returned.
Syntax
Oracle
sde.st_relate (g1 st_geometry, g2 st_geometry, patternMatrix String)
PostgreSQL
st_relate (g1 st_geometry, g2 st_geometry, patternMatrix string)
Return type
Boolean
Example
A DE-9IM pattern matrix is a device for comparing geometries. There are several types of such matrices. For example, the equals pattern matrix will tell you if any two geometries are equal.
The table RELATE_TEST is created with the following CREATE TABLE statement.
Oracle
CREATE TABLE RELATE_TEST (g1 sde.st_geometry, g2 sde.st_geometry, g3 sde.st_geometry);
PostgreSQL
CREATE TABLE relate_test (g1 st_geometry, g2 st_geometry, g3 st_geometry);
The following INSERT statements insert a sample subclass into the RELATE_TEST table.
Oracle
INSERT INTO RELATE_TEST VALUES (
sde.st_pointfromtext ('point (10.02 20.01)', 0),
sde.st_pointfromtext ('point (30.01 20.01)', 0)
PostgreSQL
st_point ('point (10.02 20.01)', 0),
st_point ('point (30.01 20.01)', 0)
The following SELECT statement and the corresponding result set list the subclass name stored in the GEOTYPE column with the dimension of that geotype.
Oracle
SELECT sde.st_relate (g1, g2, 'T*F**FFF*') equals, sde.st_relate (g1, g3, 'T*F**FFF*') not_equals
FROM relate_test;
equals     not_equals
1          0
PostgreSQL
SELECT st_relate (g1, g2, 'T*F**FFF*') AS equals, st_relate (g1, g3, 'T*F**FFF*') AS not_equals
FROM relate_test;
equals     not_equals
t          f
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial relationships
