ArcGIS Server Banner
ST_Union
ST_Union
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_Union returns an ST_Geometry object that is the union of two source objects.
Syntax
Oracle
sde.st_union (g1 sde.st_geometry, g2 sde.st_geometry)
PostgreSQL
st_union (g1 st_geometry, g2 st_geometry)
Return type
ST_Geometry
Example
The sensitive_areas table stores the IDs of threatened institutions in addition to the zone column, which stores the institutions' ST_Polygon geometries.
The hazardous_sites table stores the identity of the sites in the id column, while the actual geographic location of each site is stored in the location point column.
Oracle
CREATE TABLE sensitive_areas (id integer,
                               zone sde.st_geometry);
CREATE TABLE hazardous_sites (id integer,
                              location sde.st_geometry);
INSERT INTO sensitive_areas VALUES (
1,
sde.st_polygon ('polygon ((20 30, 30 30, 30 40, 20 40, 20 30))', 0)
2,
sde.st_polygon ('polygon ((30 30, 30 50, 50 50, 50 30, 30 30))', 0)
3,
sde.st_polygon ('polygon ((40 40, 40 60, 60 60, 60 40, 40 40))', 0)
INSERT INTO hazardous_sites VALUES (
4,
sde.st_point ('point (60 60)', 0)
5,
sde.st_point ('point (30 30)', 0)
PostgreSQL
                               zone st_geometry);
                              location st_geometry);
1,
2,
3,
4,
5,
The ST_Buffer function generates a buffer surrounding the hazardous waste site locations. The ST_Union function generates polygons from the union of the buffered hazardous waste sites and sensitive area polygons. The ST_Area function returns the area of these polygons.
Oracle
SELECT sa.id SA_ID, hs.id HS_ID,
sde.st_area (sde.st_union (sde.st_buffer (hs.location, .01), sa.zone)) UNION_AREA
FROM hazardous_sites hs, sensitive_areas sa;
     SA_ID  HS_ID     UNION_AREA
         1    4       100.000314
         2    4       400.000314
         3    4       400.000235
         1    5       100.000235
         2    5       400.000235
         3    5       400.000314
PostgreSQL
SELECT sa.id AS SA_ID, hs.id AS HS_ID,
st_area (st_union (st_buffer (hs.location, .01), sa.zone)) AS UNION_AREA
     sa_id  hs_id   union_area
         1    4       100.000314
         2    4       400.000314
         3    4       400.000235
         1    5       100.000235
         2    5       400.000235
         3    5       400.000314
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial operations
