ArcGIS Server Banner
ST_Y
ST_Y
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Definition
ST_Y can take an ST_Point as an input parameter and return its y-coordinate.
Syntax
Oracle
sde.st_y (p1 sde.st_point)
PostgreSQL
st_y (p1 st_point)
Return type
Double precision
Example
The y_test table is created with two columns: the gid column, which uniquely identifies the row, and the pt1 point column.
Oracle
CREATE TABLE y_test (gid integer unique, pt1 sde.st_point);
PostgreSQL
CREATE TABLE y_test (gid integer unique, pt1 st_point);
The INSERT statements insert two rows. One is a point without a z-coordinate or measure. The other has both a z-coordinate and measure.
Oracle
INSERT INTO y_test VALUES (
1,
sde.st_pointfromtext ('point (10.02 20.01)', 0)
2,
sde.st_pointfromtext ('point zm(10.02 20.01 5.0 7.0)', 0)
PostgreSQL
1,
st_point ('point (10.02 20.01)', 0)
2,
st_point ('point zm(10.02 20.01 5.0 7.0)', 0)
The query lists the gid column and the double-precision y-coordinate of the points.
Oracle
SELECT gid, sde.st_y (pt1) "The Y coordinate"
FROM y_test;
       GID     The Y coordinate
         1          20.01
         2          20.01
PostgreSQL
SELECT gid, st_y (pt1) AS "The Y coordinate"
FROM y_test;
       gid    The Y coordinate
         1          20.01
         2          20.01
See Also
  • An overview of SQL functions used with ST_Geometry types
