ArcGIS Server Banner
System tables of a geodatabase in Informix
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
The system tables for a geodatabase enforce geodatabase behavior, store information about the geodatabase, and keep track of the data stored in the geodatabase.
To see a diagram of the geodatabase system tables, click here. (You need Adobe Reader to open this file.)
The following is an alphabetical list of the geodatabase system tables as they appear in an Informix DBMS. You can use the following links to jump to specific places in the list.
A B C D E F G H I J K L M
N O P Q R S T U V W X Y Z
NOTE: The system tables should not be altered using anything other than the ArcGIS software.
column_registry
The column_registrytable manages all registered columns.
NOTE: If you alter column definitions using a SQL interface, the records in the column_registry table are not updated. This may cause any subsequent exports of the data to fail.
Field name Field type Description
database_name Varchar(32) Name of the database in which the table that contains the column is stored
NOT NULL
table_name Varchar(128) Name of the table that contains the registered column
NOT NULL
owner Varchar(32) Owner of the table in which the column resides (the user who created the table)
NOT NULL
column_name Varchar(32) Name of the registered column
NOT NULL
sde_type Int Code for the column's data type; possible values and their definitions include
1 = SE_INT16_TYPE—2-byte Integer
2 = SE_INT32_TYPE —4-byte Integer
3 = SE_FLOAT32_TYPE—4-byte Float
4 = SE_FLOAT64_TYPE—8-byte Float
5 = SE_STRING_TYPE—Null Term; Character Array
6 = SE_BLOB_TYPE—Variable Length Data
7 = SE_DATE_TYPE—Struct tm Date
8 = SE_SHAPE_TYPE—Shape geometry (SE_SHAPE)
9 = SE_RASTER_TYPE—Raster
10 = SE_XML_TYPE—XML Document
11 = SE_INT64_TYPE—8-byte Integer
12 = SE_UUID_TYPE—A Universal Unique ID
13 = SE_CLOB_TYPE—Character variable length data
14 = SE_NSTRING_TYPE—UNICODE Null Term; Character Array
15 = SE_NCLOB_TYPE—UNICODE Character Large Object
20 = SE_POINT_TYPE—Point UDT
21 = SE_CURVE_TYPE—LineString UDT
22 = SE_LINESTRING_TYPE—LineString UDT
23 = SE_SURFACE_TYPE—Polygon UDT
24 = SE_POLYGON_TYPE— Polygon UDT
25 = SE_GEOMETRYCOLLECTION_TYPE 25 /* MultiPoint UDT */
26 = SE_MULTISURFACE_TYPE—LineString UDT
27 = SE_MULTICURVE_TYPE—LineString UDT
28 = SE_MULTIPOINT_TYPE—MultiPoint UDT
29 = SE_MULTILINESTRING_TYPE—MultiLineString UDT
30 = SE_MULTIPOLYGON_TYPE—MultiPolygon UDT
31 = SE_GEOMETRY_TYPE—Geometry UDT
NOT NULL
column_size Int The registered column value's length
decimal_digits Int Number of integers to the right of the decimal in the column value
description Varchar(65) A description of the type of column
object_flags Int Stores the column properties; properties include
  • Column has a row ID
  • SDE controls the row ID column
  • Column allows NULLS
  • Column stores Oracle LONG RAW data
  • Column stores BLOB data
  • Column stores CLOB data
  • Column stores ST_GEOMETRY geometry data
  • Column stores binary geometry data
  • Column stores UDT geometry data
  • Column stores Oracle LOB geometry data
  • Column stores binary raster data
  • Column stores UDT raster data
  • Column stores XML data
  • Column stores dates
  • Column stores time
  • Column stores a time stamp
  • Column stores a Unicode string
NOT NULL
object_id Int Value set to the rastercolumn_id of the sde.raster_columns table if the column is a raster column or the layer_id of the sde.layers table if this column is a geometry column
compress_log
The compress_log table tracks all compress operations performed on the geodatabase.
NOTE: This table is not present if the geodatabase has never been compressed.
compress_id Serial Unique identifier of a compress operation
NOT NULL
sde_id Int Process identification number of the compress operation; references sde_id column in the process_information table
NOT NULL
server_id Int System process_id of the ArcSDE server process that performed or is performing the compress operation
NOT NULL
direct_connect Varchar(1) Y (yes) or N (no) if the client is making a direct connection to the geodatabase
NOT NULL
compress_start Datetime The date and time the compress operation was begun
NOT NULL
start_state_count Int The number of states present when compress began
NOT NULL
compress_end Datetime The date and time the compress operation completed
NOT NULL
end_state_count Int The number of remaining states after the compress operation
NOT NULL
compress_status Varchar(20) Indicates whether or not the compress operation was successfully completed
NOT NULL
dbtune
The dbtune table stores the configuration keywords forArcSDE data objects, such as feature classes.
keyword Varchar(32) The configuration keyword
NOT NULL
parameter Varchar(32) The configuration parameter
NOT NULL
config_string Char(2048) The value of the configuration parameter
gcdrules
The gcdrules table stores the geocoding rules that are used by address locators to match addresses. Each record in the gcdrules table corresponds to a geocoding rule file.
id Int The table's primary key
NOT NULL
style Varchar(32) Name of the geocoding rule set
type Varchar(3) The type of geocoding rule file; represented by a three-letter code
cls = Classification table
dct = Match key dictionary
pat = Pattern
stn = Standardization processes
mat = Matching specification
tbl = Additional tables (optional)
data BLOB The contents of the geocoding rule file
gdb_annosymbols
The gdb_annosymbols table contains feature class annotation.
id Int Uniquely identifies an annotation symbol
Primary key
NOT NULL
symbol BLOB Stores the annotation symbology
gdb_attrrules
The gdb_attrrules table contains the attribute rules in the geodatabase.
ruleid Int Identification number of the attribute rule; corresponds to the ruleid column in the gdb_validrules table
Primary key
NOT NULL
subtype Int Subtype code associated with the rule
NOT NULL
fieldname Varchar(32) Field with which the rule is associated
NOT NULL
domainname Varchar(160) Name assigned to the attribute domain in the geodatabase; references domainname field in the gdb_domains table
NOT NULL
gdb_codeddomains
The gdb_codeddomains table contains values for each coded-value domain.
domainid Int Unique identifier of the domain; corresponds to the id field in the gdb_domains table
Primary key
NOT NULL
codedvalues BLOB Contains the set of coded values and their descriptions
gdb_defaultvalues
The gdb_defaultvalues table contains the default values for fields at the subtype or object class level.
classid Int The object class ID; foreign key to the id field of the gdb_objectclasses table
NOT NULL
fieldname Varchar(32) The name of the field to which the default value applies
NOT NULL
subtype Int Subtype code for which the default value is specified for a particular field
NOT NULL
defaultstring Varchar(160) The text that is the default value for a field that is a string type
defaultnumber Decimal(32,8) The numeric value that is the default for a field that is an integer type
gdb_domains
The gdb_domains table contains the attribute constraints associated with attribute rules of the gdb_attrrules table.
id Int Unique identifier of the domain.
Primary key.
NOT NULL.
owner Varchar(32) User who created the attribute domain.
NOT NULL.
domainname Varchar(160) Name assigned to the attribute domain in the geodatabase.
NOT NULL.
description Varchar(255) Optional text describing the attribute domain.
domaintype Int Code indicating whether this is a range (1) or coded value (2) domain.
NOT NULL.
fieldtype Int Code indicating what type of field the domain applies to:
0 = Short integer
1 = Long integer
2 = Float
3 = Double
4 = Text
5 = Date
NOT NULL.
mergepolicy Int Code indicating the policy to use to assign to the resultant feature when two features are merged:
1 = sum values—The attribute of the feature that results from a merge will be the sum of the values of the two original (premerge) features.
2 = geometry weighted—The attribute of the feature that results from a merge is the weighted average of the values of the attributes of the original (premerge) features. The average is based on the original features' geometry.
3 = default value—The attribute of the feature created as a result of the merge will be the same as the default value of the feature class or subtype. (Note: This is the only merge policy value available for nonnumeric fields and coded value domains.)
NOT NULL.
splitpolicy Int Code indicating the policy to be used for assigning attributes to the features that result from splitting one feature:
1 = geometry ratio—The attributes of the features resulting from the split are a ratio of the original feature's (presplit) value. The ratio is based on the ratio in which the geometry is divided by the split.
2 = duplicate—The attribute of the features resulting from the split are the same as the original object's (presplit) attribute value.
3 = default value—The attributes of features resulting from the split take on the default value for the attribute as defined in the feature class or subtype.
NOT NULL.
gdb_edgeconnrules
The gdb_edgeconnrules table contains one record per edge connectivity rule in a geometric network.
ruleid Int The unique identifier for a rule in the geodatabase and foreign key to the id field in the gdb_validrules table
NOT NULL
fromclassid Int The object class ID of the from feature class and the foreign key to the ID in the gdb_geomnetworks table
NOT NULL
fromsubtype Int The subtype of the from edge feature class
NOT NULL
toclassid Int The object class ID of the to feature class and the foreign key to the ID in the gdb_geomnetworks table
NOT NULL
tosubtype Int The subtype of the to edge feature class
NOT NULL
junctions Blob Contains information related to the junction feature class
NOT NULL
gdb_extensiondatasets
The gdb_extensiondatasets table contains information about the dataset extensions (such as network datasets or terrain datasets) in a geodatabase.
id Int Unique identification number for the network dataset
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the dataset resides
NOT NULL
owner Varchar(32) Owner of the dataset
NOT NULL
name Varchar(160) Name of the dataset
NOT NULL
datasetid Int Foreign key to datasetid field in related tables
NOT NULL
properties Blob Properties specific to the dataset
datasettype Int The type of dataset within the geodatabase
NOT NULL
gdb_extensions
The gdb_extensions table stores the extensions registered with this geodatabase.
id Int Unique identifier of the workspace extension
Primary key
NOT NULL
name Varchar(160) Name of the workspace extension
NOT NULL
clsid Varchar(38) GUID that uniquely identifies the extension of an object class
NOT NULL
gdb_featureclasses
The gdb_featureclasses table contains information on all the feature classes in the geodatabase.
objectclassid Int Foreign key to the id field in the gdb_objectclasses table
NOT NULL
featuretype Int Code representing the type of feature
1 = point, multipoint, line, polygon, or multipatch
7 = junctions
8 = simple edges
10 = complex edges
11 = annotation
13 = dimension
14 = raster
NOT NULL
geometrytype Int Code representing the type of geometry of the feature class
1 = point
2 = multipoint
3 = line
4 = polygon (including anno and dimension)
9 = multipatch
NOT NULL
shapefield Varchar(32) Name of the shape field in the feature class
NOT NULL
geomnetworkid Int Foreign key to the id field in the gdb_geomnetworks table
graphid Int Foreign key to id in the gdb_networks table
gdb_featuredataset
The gdb_featuredataset table contains the feature datasets (groupings of feature classes) in the geodatabase.
id Int Uniquely identifies the feature dataset
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the feature dataset is stored
owner Varchar(32) User who created the feature dataset
name Varchar(160) Name of the feature dataset
NOT NULL
srid Int Spatial reference ID number; foreign key to spatial_references table
NOT NULL
gdb_fieldinfo
The gdb_fieldinfo table contains the field name, default domain names values and default string and number values for each attribute field associated with a feature class.
NOT NULL
fieldname Varchar(160) Name of the field in the table
NOT NULL
aliasname Varchar(160) Alternate name assigned to the field (Aliases can be altered after field creation, the field name cannot.)
modelname Varchar(160) Alternate name assigned to the field used to identify a type of field without requiring a hard coded name
defaultdomainname Varchar(160) Name of the domain associated with the field
defaultvaluestring Varchar(160) If the field is type text, the default value assigned to it
defaultvaluenumber Decimal(38,8) If the field is a numeric type, the default value assigned to it
isrequired Int 0 (not a required field) or 1 (a required field)
issubtypefixed Int Denotes whether subtype is set for the field
0 = yes
1 = no
iseditable Int 0 (not editable) or 1 (editable)
gdb_geomnetworks
The gdb_geomnetworks table contains one record per geometric network in the geodatabase. If no stand-alone logical networks exist in the geodatabase, there will be a one-to-one mapping of the gdb_geomnetworks and gdb_networks tables.
id Int Unique identifier and primary key for geometric network in the geodatabase
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the geometric network is stored
owner Varchar(32) The name of the user who created the geometric network
NOT NULL
name Varchar(160) The name of the geometric network, which must be unique in a personal geodatabase
NOT NULL
networktype Int The type of geometric network
NOT NULL
datasetid Int Foreign key to ID field in gdb_objectclasses table
NOT NULL
gdb_historicalmarkers
The gdb_historicalmarkers table contains a list of markers used for navigating moments in a historical version.
hm_name Varchar(64) The name of the historical marker
hm_timestamp datetime The moment the historical marker references
gdb_jnconnrules
The gdb_jnconnrules contains one record per junction connectivity rule in a geometric network.
ruleid Int Primary key, the unique ID for a rule in a geodatabase and the foreign key to the id field in the gdb_validrules table
NOT NULL
edgeclassid Int The object class ID of the edge feature class and the foreign key to the ID field in the gdb_geomnetworks table
NOT NULL
edgesubtype Int The subtype of the edge feature class
NOT NULL
junctionclassid Int The object class ID of the junction feature class and the foreign key to the ID field in the gdb_geomnetworks table
NOT NULL
junctionsubtype Int The subtype of the junction feature class
NOT NULL
edgemincard Int The minimum edge cardinality (the minimum number of edges to which a junction can connect)
NOT NULL
edgemaxcard Int The maximum edge cardinality (the maximum number of edges to which a junction can connect)
NOT NULL
junctionmincard Int The minimum junction cardinality (the minimum number of junctions to which an edge can connect)
NOT NULL
junctionmaxcard Int The maximum junction cardinality (the maximum number of junctions to which an edge can connect)
NOT NULL
isdefault Int Will contain a value of 0 or 1 indicating if a junction is a default junction and has been created automatically
gdb_netclasses
The gdb_netclasses table contains one record per feature class that participates in a geometric network in a geodatabase.
classid Int The object class ID of a feature class in a geodatabase and the foreign key to the ID field in the gdb_geomnetworks table
NOT NULL
networkid Int The unique ID for a geometric network in a geodatabase
NOT NULL
enabledfield Varchar(32) The Enabled field name for the feature class (usually "Enabled")
(Every feature class in a geometric network must have an enabled field.)
ancillaryrole Int Indicates whether the junction feature class acts as a source or a sink in a geometric network
ancillaryfield Varchar(32) The AncillaryRole field name for the feature class (usually "AncillaryRole")
gdb_netweightasocs
The gdb_netweightasocs table contains one record per association between the network classes and the network weights of the geometric networks.
networkid Int The unique identifier for a geometric network in a geodatabase and a foreign key to the ID field in the gdb_geomnetworks table
NOT NULL
weightid Int The unique identifier of a weight in a geometric network and the foreign key to the classid field in the gdb_netclasses table
NOT NULL
tablename Varchar(160) The name of the table containing the field with which the network weight has been associated
NOT NULL
fieldname Varchar(32) The name of the field with which the weight has been associated
NOT NULL
gdb_netweights
The gdb_netweights table contains one record per weight in a geodatabase.
oid Int The unique identifier of a weight in a geodatabase
NOT NULL
networkid Int The unique ID for the geometric network in a geodatabase and the foreign key to the ID fields in the gdb_geomnetworks, gdb_networks, and gdb_extensiondatasets tables
NOT NULL
name Varchar(160) The name of the weight, which must be unique in each network
NOT NULL
weightid Int The unique ID of the weight in the geometric network
NOT NULL
weighttype Int A value indicating the type of network weight
NOT NULL
bitgatesize Int A value from 0 to 31 indicating the size of the BitGate weight
(NonBitGate weights have a value of 0.)
elementtypes Int Denotes the type of network weight
gdb_networks
The gdb_networks table contains one record per logical network in the geodatabase. If no stand-alone logical networks exist within the geodatabase, there will be a one-to-one mapping between the gdb_geomnetworks and the gdb_networks tables.
id Int The unique identifier and primary key of the logical network in a geodatabase.
NOT NULL.
databasename Varchar(32) The name of the database in which the network is stored.
NOT NULL.
owner Varchar(32) The name of the user who created the logical network.
NOT NULL.
name Varchar(160) The name of the logical network.
NOT NULL.
networktype Int A value indicating the type of network.
All networks created using ArcGIS Desktop will have a value of 1=esriNTUtilityNetwork.
NOT NULL.
indextype Int Not currently implemented.
normalized Int A value of either 0 or 2, which indicates whether the network is narrow or wide.
Narrow networks contain feature classes with ObjectIDs less than 10,000; wide networks can contain feature classes with ObjectIDs greater than 10,000.
NOT NULL.
gdb_objectclasses
The gdb_objectclasses contains all the object classes in the geodatabase. This includes the feature classes, relationship classes, and business (or base) tables.
id Int Unique identifier for the object class
Primary key
NOT NULL
databasename Varchar(32) Database in which the object class is stored
NOT NULL
owner Varchar(32) User who owns the object class
NOT NULL
name Varchar(160) Name of the object class
NOT NULL
aliasname Varchar(160) Alternative name of the object class
modelname Varchar(160) Alternate name of the object class; used to identify the type of entity without requiring a hard-coded name
clsid Varchar(38) GUID that uniquely identifies the type of object class
NOT NULL
extclsid Varchar(38) GUID that uniquely identifies the extension of an object class
extprops BLOB Stores the properties of the associated class extension
subtypefield Varchar(32) Name of the field in the object class for defining subtypes
datasetid Int Foreign key to the ID field in the gdb_featuredatasets table
gdb_rangedomains
The gdb_rangedomains table contains the range of values for each range domain.
domainid Int Foreign key to the ID field in the gdb_domains table
NOT NULL
minvalue Decimal(32,8) The lowest allowable value in the range
NOT NULL
maxvalue Decimal(32,8) The greatest allowable value in the range
NOT NULL
gdb_rastercatalogs
The gdb_rastercatalogs table stores a reference to each raster catalog in the geodatabase.
objectclassid Int Foreign key to the ID field in the gdb_objectclasses table
NOT NULL
rasterfield Varchar(32) Name of the field in the table that holds the raster
NOT NULL
israsterdataset Int 0 (not a raster dataset) or 1 (a raster dataset)
NOT NULL
gdb_relclasses
The gdb_relclasses table contains the table relationships in the geodatabase. All the system metadata required to manage relationships, such as the cardinality and the IDs of the origin and destination classes, is stored in the gdb_relclasses table.
id Int Unique identifier of the relationship class.
Primary key.
NOT NULL.
databasename Varchar(32) Name of the database in which the relationship class resides.
NOT NULL.
owner Varchar(32) User who owns the relationship class.
NOT NULL.
name Varchar(160) Name of the relationship class.
NOT NULL.
originclassid Int Object class ID of the origin object class.
NOT NULL.
destclassid Int Object class ID of the destination object class.
NOT NULL.
forwardlabel Varchar(255) Label that describes the relationship when navigating from origin class to destination class.
backwardlabel Varchar(255) Label that describes the relationship when navigating from destination class to origin class.
cardinality Int Code representing the type of cardinality of the relationship class:
1 = one to one
2 = one to many
3 = many to many
NOT NULL.
notification Int Code indicating the notification direction:
1 = none (no messages propagated)
2 = forward (origin to destination)
3 = backward
4 = both (forward and backward notification)
NOT NULL.
iscomposite Int If a relationship class is composite, destination objects cannot exist independently of their related origin objects.
Possible values are
0 (is simple, not composite) or 1 (is composite).
NOT NULL.
isattributed Int Indicates whether or not this is an attributed relationship.
NOT NULL.
originprimarykey Varchar(32) The name of the primary key field of the origin object class.
NOT NULL.
destprimarykey Varchar(32) The name of the primary key field in the destination object class.
NOT NULL.
originforeignkey Varchar(32) The name of the foreign key field of the origin object class.
NOT NULL.
destforeignkey Varchar(32) The name of the foreign key field in the destination object class.
NOT NULL.
datasetid Int Foreign key to the gdb_featuredataset table.
gdb_release
The gdb_release table stores geodatabase version release information as a single record.
major Int Number of the release for the geodatabase. For example, ArcGIS 8 was the first major release for the geodatabase, 9 was the second.
NOT NULL.
minor Int The number release of the major release. For example, for 9.1, this would be 1.
NOT NULL.
bugfix Int Not in use at this time.
The number of the patch or service pack installed. If 0, no service pack or patch is installed.
NOT NULL
gdb_relrules
The gdb_relrules table contains the object class relationship rules.
Field name Field type Descripton
ruleid Int Unique identifier of the rule and foreign key to the ID field in the gdb_validrules table
Primary key
NOT NULL
originsubtype Int The subtype of the origin feature class
NOT NULL
originmincard Int Minimum number of origin features to which a destination feature can connect
NOT NULL
originmaxcard Int Maximum number of origin features to which a destination feature can connect
NOT NULL
destsubtype Int The subtype of the destination feature class
NOT NULL
destmincard Int Minimum number of destination features to which an origin feature can connect
NOT NULL
destmaxcard Int Maximum number of destination features to which an origin feature can connect
NOT NULL
gdb_replicadatasets
The gdb_replicadatasets table contains information relating to each dataset that was checked out or replicated.
id Int The unique identifier for each record in the table
Primary key
NOT NULL
replicaid Int The identifier of the replica in the parent database
NOT NULL
datasettype Int The type of each dataset in the replica
NOT NULL
datasetid Int The ID of each dataset in the replica
NOT NULL
parentowner Varchar(32) The owner of the data in the parent geodatabase
NOT NULL
parentdb Varchar(32) The name of the database in the parent database
gdb_replicalog
Each time a replica exports or imports changes, information about the operation is stored in the gdb_replicalog table.
id Int Unique identifier for row.
NOT NULL.
replicaid Int Foreign key to the ID field in the gdb_replicas table.
NOT NULL.
event Int Indicates if an import (1) or an export (2) has been logged.
NOT NULL.
errorcode Int The error code associated with the event; you can search the developer help to get the description associated with the error. If the event was successful, a success error code is returned.
NOT NULL.
logdate Datetime The date on which the event occurred.
NOT NULL.
sourcebegingen Int Several generations of data changes may be imported or exported in one event. This value indicates the generation number of the first generation of changes involved. For example, if generations 1 to 3 were imported, this field would have the value 1.
NOT NULL.
sourceendgen Int Several generations of data changes may be imported or exported in one event. This value indicates the generation number of the last generation of changes involved. For example, if generations 1 to 3 were imported, this field would have the value 3.
NOT NULL.
targetgen Int The generation to which changes are to be applied; this value is used to apply changes to the appropriate version in the target replica.
NOT NULL.
gdb_replicas
The gdb_replicas table contains the metadata for each replica in the geodatabase.
id Int Unique identifier for the replica (child) version
Primary key
NOT NULL
name Varchar(32) Name of the replica (child) version of the geodatabase
NOT NULL
owner Varchar(32) User who owns the replica (child) version of the geodatabase
NOT NULL
version Varchar(64) Name of the replica version in the parent geodatabase
NOT NULL
parentid Int Identifier of the replica in the parent geodatabase
NOT NULL
repdate Datetime Date and time the replica was created
NOT NULL
defquery BLOB Contains the replica description, which describes datasets and filters that define the replica
NOT NULL
repguid Varchar(36) The GUID value that uniquely identifies the replica across geodatabases
NOT NULL
repcinfo Char(1800) The connection information for the relative replicas geodatabase
role Int Indicates if a replica has the role of parent or child
NOT NULL
gdb_replicasex
The gdb_replicasex table has additional information about each replica that is stored in the gdb_replicas table. It also has one record of metadata for each replica.
id Int Unique identifier for the row
Primary key
NOT NULL
replicaid Int Foreign key to ID field in gdb_replicas table
NOT NULL
rprops BLOB Extra replica properties, such as generation numbers or replica state, are stored in this field.
dprops BLOB Replica description parameters
NOT NULL
gdb_spatialrules
The gdb_spatialrules table is not in use at this time.
NOT NULL
subtype Int
NOT NULL
spatialrel Int
NOT NULL
distance Decimal(32,8)
NOT NULL
refclassid Int
NOT NULL
refsubtype Int
NOT NULL
gdb_subtypes
The gdb_subtypes table contains the valid subtypes of the geodatabase object classes.
id Int Unique identifier of the subtype
NOT NULL
NOT NULL
subtypecode Int Numeric code value representing a subtype; foreign key to SUBTYPE field in gdb_defaultvalues table and destclasssubtype field in the gdb_toporules table
NOT NULL
subtypename Varchar(160) Name of the subtype; corresponds to the Subtype Description on the Subtypes tab of the Feature Class Properties dialog box in ArcCatalog
NOT NULL
gdb_tables_last_modified
The gdb_tables_last_modified table is used to validate geodatabase system tables when cached by the client application.
table_name Varchar(160) Name of the geodatabase system table
NOT NULL
last_modified_count Int Keeps a count of the number of times a system table is modified; incrementally increases each time the system table is modified
NOT NULL
gdb_toolboxes
The gdb_toolboxes table contains one record of metadata for each toolbox in the geodatabase.
id Int Unique identifier for the toolbox
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the toolbox is stored
NOT NULL
owner Varchar(32) User who created the toolbox in the geodatabase
NOT NULL
name Varchar(160) Name given to the toolbox
NOT NULL
displayname Varchar(255) The label of the toolbox
alias Varchar(160) Alternative name for the toolbox
helpfile Varchar(255) Path to the help file containing the help topic for the toolbox
helpcontext Int Help context identifier from the help file for the help topic associated with the toolbox
gdb_topoclasses
The gdb_topoclasses table contains one record per each feature class in a topology.
classid Int Unique identifier of the topology class;
foreign key to ID field in the gdb_objectclasses table
NOT NULL
topologyid Int Foreign key to ID field in GDB_TOPOLOGIES table
NOT NULL
weight Decimal(32,8) Not in use
xyrank Int The rank in the x,y domain assigned to the feature class in the topology
NOT NULL
zrank Int The rank in the z domain assigned to the feature class in the topology
NOT NULL
eventsonanalyze Int Indicates if an event is broadcast when topology is validated
NOT NULL
gdb_topologies
The gdb_topologies table contains one record per topology in the geodatabase.
id Int Primary key and the unique identifier for the topology in the geodatabase
NOT NULL
databasename Varchar(32) Name of the database in which the topology resides
NOT NULL
owner Varchar(32) The owner of the topology (the user who created the topology)
NOT NULL
name Varchar(160) The name of the topology
NOT NULL
datasetid Int The feature dataset in which the topology resides and the foreign key to the ID field in the gdb_featuredatasets table
NOT NULL
properties BLOB Stores information such as the cluster tolerance, max error count, state, and configuration keyword
gdb_toporules
The gdb_toporules table contains one record per rule in each topology.
ruleid Int Unique identifier of the topology rule; foreign key to the id field in the gdb_validrules table
NOT NULL
originclassid Int Foreign key to classid field in gdb_topoclasses table
NOT NULL
originsubtype Int Foreign key to subtypecode field in gdb_subtypes table
NOT NULL
alloriginsubtypes Int Indicates if rule applies to all subtypes in the origin feature class
NOT NULL
destclassid Int Foreign key to classid field in gdb_topoclasses table
NOT NULL
destsubtype Int Foreign key to subtypecode field in gdb_subtypes table
NOT NULL
alldestsubtypes Int Indicates if rule applies to all subtypes in the destination feature class
NOT NULL
topologyruletype Int The type of topology rule
NOT NULL
name Varchar(160) User-defined name associated with the topology rule
ruleguid Varchar(38) GUID that uniquely identifies the topology rule
NOT NULL
gdb_usermetadata
The gdb_usermetadata table stores user-defined metadata for all parts of the geodatabase including object classes, feature classes, feature datasets, logical networks, and relationship classes.
id Int Uniquely identifies the metadata record
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the metadata resides
owner Varchar(32) Owner of the metadata
NOT NULL
name Varchar(160) Name of the dataset to which the metadata refers
NOT NULL
datasettype Int Code for the type of dataset to which the metadata refers
NOT NULL
xml BLOB Metadata content
NOT NULL
gdb_validrules
The gdb_validrules table contains all the valid rules of the geodatabase. This includes the attribute rules, edge connectivity rules, junction connectivity rules, relationship rules, topology rules, geocoding rules, and spatial rules.
id Int Uniquely identifies a rule
Primary key
NOT NULL
ruletype Int The type of validation rule
NOT NULL
classid Int Foreign key to ID field in gdb_objectclasses table
NOT NULL
rulecategory Int Not in use at this time
helpstring Varchar(160) Not in use at this time
geometry_columns
The geometry_columns table stores a row for each column of type Geometry in the database that complies with the OpenGIS SQL specification. ArcSDE treats this table as write-only—the only time it is accessed by ArcSDE is when a layer is added or deleted that uses an OpenGIS SQL data format. This table is defined by the OpenGIS SQL specification and may be updated by other applications with geometry columns not managed by ArcSDE. When a new Geometry column is created in an OpenGIS compliant format, the fully qualified table, column name, and spatial reference ID (SRID) are added to the geometry_columns table.
Each geometry column is associated with a spatial reference system. ArcSDE stores information on each spatial reference system in the spatial_references table.
f_table_catalog Varchar(32) The database in which the geometry column's table is stored
NOT NULL
f_table_schema Varchar(32) The owner of the geometry column's table
NOT NULL
f_table_name Varchar(128) The geometry column's table name
NOT NULL
f_geometry_column Varchar(128) The name of the geometry column
NOT NULL
storage_type Int An OGC required field not used by ArcSDE
geometry_type Int The geometry type code; ArcSDE inserts the following values into this field:
0 = ST_Geometry
1 = ST_Point
3 = ST_LineString
5 = ST_Polygon
7 = ST_MultiPoint
9 = ST_MultiLineString
11 = ST_MultiPolygon
coord_dimension Int Code for the coordinate dimension
0 = point
1 = linear
2 = area
srid Int The geometry column's spatial reference system; a foreign key to the SRID column of the spatial_references table
NOT NULL
layer_locks
The layer_locks table maintains the locks on feature classes.
sde_id Int Process identification number of the process that has locked the layer; foreign key to the sde_id column in PROCESS_INFORMATION table
NOT NULL
layer_id Int Foreign key to layer_id field in LAYERS table
NOT NULL
autolock Char(1) Set to 1 if the layer lock was set internally; otherwise, set to 0 if the layer lock was set by the application
NOT NULL
lock_type Char(1) The type of layer lock can either be
0 = A read lock on the entire layer
1 = A write lock on the entire layer
2 = A read lock on an area within the layer
3 = A write lock on an area within the layer
4 = A layer autolock
NOT NULL
minx Int The minimum x-coordinate of the bounding box used to define the features within an area locked during an area lock
miny Int The minimum y-coordinate of the bounding box used to define the features within an area locked during an area lock
maxx Int The maximum x-coordinate of the bounding box used to define the features within an area locked during an area lock
maxy Int The maximum y-coordinate of the bounding box used to define the features within an area locked during an area lock
layers
The layers table maintains data about each feature class in the database. The information helps build and maintain spatial indexes, ensure proper shape types, maintain data integrity, and store the spatial reference for the coordinate data.
This table stores a row for each spatial column in the database. Applications use the layer properties to discover available spatial data sources. The layer properties are used by ArcSDE to constrain and validate the contents of the spatial column, to index geometry values, and to properly create and manage the associated DBMS tables.
layer_id Int Unique identifier for the layer
Primary key
NOT NULL
description Varchar(65) The optional layer description
databasename Varchar(32) Name of the database in which the layer is stored
owner Varchar(32) The user who created the layer
NOT NULL
table_name Varchar(128) Name of the business table of the layer
NOT NULL
spatial_column Varchar(128) Name of the spatial column in the layer
NOT NULL
eflags Int Stores the following layer properties:
  • Layer stores single precision or double precision coordinates.
  • Layer stores 3D coordinates
  • Layer stores measures
  • Layer has autolocking enabled or disabled.
  • Layer is in load only I/O mode or normal I/O mode
  • Layer stores annotation
  • Layer stores CAD data
  • Layer is a view of another layer
  • Layer does not have a spatial index
  • The DBMS data type in which the layer data is stored
  • The sde types that the layer can accept, which can be such types as points, linestrings, polygons
NOT NULL
layer_maks Int Stores additional internal properties about the layer
NOT NULL
minx Float Minimum x-coordinate value of the layer
NOT NULL
miny Float Minimum y-coordinate value of the layer
NOT NULL
maxx Float Maximum x-coordinate value of the layer
NOT NULL
maxy Float Maximum y-coordinate vlue of the layer
NOT NULL
minz Float Minimum z-coordinate value of the layer
maxz Float Maximum z-coordinate value of the layer
minm Float Minimum measure value of the layer
maxm Float Maximum measure value of the layer
cdate Int The layer creation date
NOT NULL
layer_config Varchar(32) Configuration keyword with which the layer was created
optimal_array_size Int Geometry array buffer size
stats_date Int When statistics were last calculated for a layer
minimum_id Int The minimum feature ID value of a binary layer
srid Int Spatial reference identification number; corresponds to srid value in the spatial_references table
NOT NULL
base_layer_id Int Stores the base layer's layer_id value for a layer that is actually a view
NOT NULL
lineages_modified
The lineages_modified table contains a state lineage ID and its most recent modification time stamp.
lineage_name Int8 Foreign key to the lineage_name field in the states_lineages table
NOT NULL
time_last_modified datetime The date and time the lineage was last modified
NOT NULL
locators
The locators table stores information about locator objects.
locator_id Int Unique identifier of the locator
Primary key
NOT NULL
name Varchar(32) The name of the locator
NOT NULL
owner Varchar(32) The name of the user who owns the locator
NOT NULL
category Varchar(32) The category of the locator; address locators have a category value of Address.
NOT NULL
type Int The type of locator; values represented as follows:
  • 0—Defines locator styles
  • 1—Defines locators
  • 2—Defines attached locators; in other words, locators that are attached to a geocoded feature class and are a copy of the locator and the geocoding options that were used to create the geocoded feature class
NOT NULL
description Varchar(64) The description of the locator
NOT NULL
metadata
When you add a locator to a geodatabase in a DBMS, a row is added to the metadata table for each property of the locator. Each row in the metadata table defines a single property for a locator.
record_id Int Unique identifier for the record
Primary key
NOT NULL
object_name Varchar(160) The name of the locator to which the property belongs and foreign key to the name column in the locators table
NOT NULL
object_database Varchar(32) Name of the database in which the locator is stored
object_owner Varchar(32) The name of the user who owns the record
NOT NULL
object_type Int Always a value of 2 for locator properties
NOT NULL
class_name Varchar(32) Always a value of SDE_internal for locator properties
property Varchar(32) The name of the locator property
prop_value Varchar(255) The value of the locator property
description Varchar(65) Not used for locator properties
creation_date datetime Date and time the locator property was created
NOT NULL
mvtables_modified
The mvtables_modified table maintains the list of all tables that are modified in each state of the database. This information aids in quickly determining if conflicts exist between versions or states of the database.
The mvtables_modified table maintains a record of all tables modified by state. This information allows applications to determine which tables need to be checked for changes when reconciling potential conflicts between versions and states in the database.
Any time a feature class or table is modified in a state, a new entry is created in the mvtables_modified table. When two versions are reconciled, the first step in the process is to identify the states these two versions reference—the current edit version’s state and the target version’s state. From these states, a common ancestor state is identified by tracing back through the state lineage of these two versions.
state_id Int8 The identifier of the state in which this table was modified; foreign key to the states table
NOT NULL
registration_id Int The registration ID of the table that was modified in the state; foreign key to the table_registry table
NOT NULL
object_locks
The object_locks table maintains locks on geodatabase objects.
sde_id Int Process identification number of the process that locked the geodatabase object; references sde_id column in process_information table
NOT NULL
object_id Int The ID from the object_classes table of the affected dataset
NOT NULL
object_type Int Object lock type; for example, version,state_tree lock used by internal applications
NOT NULL
application_id Int Application unique identifier
NOT NULL
autolock Char(1) Set to Y if the layer lock was set internally; otherwise, set to N if the layer lock was set by the application
NOT NULL
lock_type Char(1) The type of object lock, which includes
"S" for shared
"E" for exclusive
NOT NULL
process_information
The process_information table collects ArcSDE session statistics such as the number of records read and the number of records written while the session was active.
Field Name Field Type Description
NOT NULL
server_id Int The operating system process ID of the server process
NOT NULL
start_time datetime Date and time process was started
NOT NULL
rcount Int The number of reads that have been processed
NOT NULL
wcount Int The number of writes that have been processed
NOT NULL
opcount Int Total number of operations a process has executed
NOT NULL
numlocks Int The number of locks that the process currently has open
NOT NULL
fb_partial Int Total number of partial features shipped by the process
NOT NULL
fb_count Int Total number of buffers loaded by the process
NOT NULL
fb_fcount Int Total number of features buffered by the process
NOT NULL
fb_kbytes Int Total number of kilobytes buffered by the process
NOT NULL
owner Varchar(30) The name of the connected user
NOT NULL
direct_connect Varchar(1) Indicates whether process was made with a direct connection—T (true) or F (false)
NOT NULL
sysname Varchar(32) The operating system that the client machine is running
NOT NULL
nodename Varchar(255) The connected client machine name
NOT NULL
xdr_needed Varchar(1) Records whether or not client is using xdr to communicate with the gsrvr
NOT NULL
raster_columns
The raster_columns table contains a list of raster columns stored in the database.
This table references the raster data in the band, block, and auxiliary tables.
rastercolumn_id Int The primary key of the raster column table.
NOT NULL.
description Varchar(65) The description of the raster table.
databasename Varchar(32) Name of the database in which the table that contains the raster column is stored.
NOT NULL.
owner Varchar(32) The owner of the raster column's business table.
NOT NULL.
table_name Varchar(128) The business table name.
NOT NULL.
raster_column Varchar(128) The raster column name.
NOT NULL.
cdate Int The date the raster column was added to the business table.
NOT NULL.
config_keyword Varchar(32) The DBTUNE configuration keyword whose storage parameters determine how the tables and indexes of the raster are stored in the database.
minimum_id Int Defined during the creation of the raster, establishes value of the raster table's raster_id column.
base_rastercolumn_id Int When the raster column is part of a view and not a table, this value is the rastercolumn_id of the base table of the view.
NOT NULL.
rastercolumn_mask Int Set to 256 for a geodatabase raster.
NOT NULL.
srid Int Spatial reference identifier number; references srid in the spatial_references table.
sde_archives
The sde_archives table stores the metadata for the archives in a geodatabase.
archiving_regid Int The table's registration ID
history_regid Int The archive table's registration ID
from_date Varchar(32) The name of the from date field
to_date Varchar(32) The name of the to date field
archive_date Datetime The creation date of the archive
archive_flags Int8 Not currently used
sde_sde_logfile_pool
The sde_sde_logfile_pool table will be present in the geodatabase when it is first created, regardless of what type of log files you use. For a description of this and other log file tables, see Log file tables in a geodatabase in Informix.
server_config
The server_config table stores ArcSDE configuration parameters. These parameters define how the ArcSDE software uses memory.
prop_name Varchar(32) The initialization parameter name
NOT NULL
char_prop_value Varchar(512) The character value of the initialization parameter
num_prop_value Int The integer value of the initialization parameter
spatial_references
The spatial_references table contains the coordinate system and floating point-to-integer transformation values. Internal functions use the parameters of a spatial reference system to translate and scale each floating-point coordinate of the geometry into 64-bit positive integers prior to storage. Upon retrieval, the coordinates are restored to their original external floating-point format.
Each geometry column of the geometry_columns table is associated with a spatial reference system, the information for which is stored in the spatial_references table. The columns of this table are those defined by the OpenGIS SQL Specification (srid, srtext, auth_name, and auth_srid) and those required by ArcSDE for internal coordinate transformation. The spatial reference system identifies the coordinate system for a geometry and gives meaning to the numeric coordinate values for the geometry.
NOT NULL
description Varchar(64) The text description of the spatial reference system
auth_name Varchar(256) The name of the standard or standards body that is being cited for this reference system; for example, POSC would be a valid AUTH_NAME
auth_srid Int The ID of the Spatial Reference System as defined by the Authority cited in AUTH_NAME
falsex Float The x offset used when transforming ground coordinates to internal system coordinates
NOT NULL
falsey Float The y offset used when transforming ground coordinates to internal system coordinates
NOT NULL
xyunits Float The scale factor to apply when transforming ground coordinates to internal system coordinates
NOT NULL
falsez Float The z offset to use when transforming z values to internal system coordinates
NOT NULL
zunits Float The scale factor to use when transforming z values to internal system coordinates
NOT NULL
falsem Float The measure offset to use when transforming measure values to internal system coordinates
NOT NULL
munits Float The scale factor to use when transforming measure values to internal system coordinates
NOT NULL
srtext Char(2048) Name and descriptor for the spaital reference as seen in the ArcGIS interface
NOT NULL
object_flags Int Stores object attributes, including precision
NOT NULL
xycluster_tol Float X,y coordinate cluster tolerance for topological processing
zcluster_tol Float Z-coordinate cluster tolerance for topological processing
mcluster_tol Float Measure cluster tolerance for topological processing
state_lineages
The state_lineages table stores the lineage of each state. A new lineage name is created for each version. Each time a state is added, the lineage name and the state ID are added. When a state is added that is a new version, the ancestry state lineage of the parent state is added with the lineage name.
To return the correct view of a version, its state lineage is queried to identify all the states that recorded each change made to that version. From this list of states, the table rows that correctly represent the version can be determined.
lineage_name Int8 Name that describes a state
NOT NULL
lineage_id Int8 Unique identifier of individual states
NOT NULL
state_locks
The state_locks table maintains the version state locks.
sde_id Int Process identification number of the process that locked the state; references sde_id column in process_information table
NOT NULL
state_id Int8 Identifier of the state that is locked
NOT NULL
NOT NULL
lock_type Char(1) The type of state lock; the following are possible types:
0 = A shared lock on the entire state tree
1 = An exclusive lock on the entire state tree
2 = A shared lock on a state
3 = An exclusive lock on a state
4 = A shared autolock
5 = An exclusive autolock
NOT NULL
states
The states table contains the state metadata. It accounts for the states that have been created over time, and the creation time, closing time, parent, and owner of each state.
When a state is created, a state ID is assigned and a record is added to this table.
Field name Field type Discussion
state_id Int8 A unique identifier for this state, assigned by ArcSDE
Primary key
NOT NULL
owner Varchar(32) The user who created this state
NOT NULL
creation_time Datetime The date/time this state was created
NOT NULL
closing_time Datetime The date/time that this state was closed
parent_state_id Int8 This state’s parent's state_id
NOT NULL
lineage_name Int8 References the state's lineage stored in the state_lineages table
NOT NULL
table_locks
The table_locks table maintains the locks on ArcSDE registered tables.
sde_id Int Process identification number of the process that locked the table; references sde_id column in process_information table
NOT NULL
registration_id Int Foreign key to registration_id field in the table_registry table
NOT NULL
lock_type Char(1) The type of table lock, which includes
"S" for shared
"E" for exclusive
NOT NULL
table_registry
The table_registry table manages all registered tables. The values include an ID, table name, owner, and description.
registration_id Int Unique identifier for the registration of the table
Primary key
NOT NULL
databasename Varchar(32) Name of the database in which the table is stored
NOT NULL
owner Varchar(32) User who created the table
NOT NULL
NOT NULL
rowid_column Varchar(32) Name of the ObjectID column in the table
description Varchar(65) The text description of the table
object_flags Int Stores the registration properties of the table, which include
  • The table has a registered row ID.
  • SDE controls the row ID.
  • The table has a geometry column.
  • The table is a multiversioned view.
  • The table can be row locked.
  • The table has a raster column.
  • The table is a view of another table.
  • The table has a geocoding locator column.
  • Data definition language operations are restricted.
  • Data manipulation language operations are restricted.
  • The table is hidden.
  • The table has single row IDs.
  • The table has an XML column.
  • The table has a layer that stores double coordinates.
  • The interior states of this versioned table can be edited.
  • This is a base save table.
  • This table has trusted shapes.
  • This is an archiving table.
  • This table is in load only I/O mode.
  • This is a history table.
NOT NULL
registration_date Int The date the table was registered
NOT NULL
config_keyword Varchar(32) Configuration keyword with which the table was created
minimum_id Int The minimum row_id value of the table
imv_view_name Varchar(32) The name of a multiversioned view of the given table
tables_modified
The tables_modified table records when changes are made to the system tables. This information is used to eliminate unnecceary reads of tables that have not changed.
table_name sysname Name of the ArcSDE system table that was modified
time_last_modified datetime Date and time the table was modified
version
The VERSION table maintains information about the version of ArcSDE with which the database expects to operate. The table contains the specific release identification for the most recently installed version of ArcSDE.
The VERSION table and other ArcSDE system tables are updated after a new version of ArcSDE is installed.
major Int Number of the major release; for example, for ArcSDE 9.1, the major release number would be 9.
NOT NULL.
minor Int Number indicating the version of the major release; for example, for ArcSDE 9.1, the minor release number would be 1.
NOT NULL.
bugfix Int Number of the patch or service pack installed.
NOT NULL.
description Varchar(96) Description of the ArcSDE installation.
NOT NULL.
release Int Complete release number; for example, 92009,
NOT NULL
sdesvr_rel_low Int Indicates the lowest release number of server allowed to run on this instance.
NOT NULL.
versions
The versions table contains information about versioned geodatabases.
name Varchar(64) The unique name of the version
NOT NULL
owner Varchar(32) The version owner
NOT NULL
version_id Int The unique identifier of the version
NOT NULL
status Int Specifies whether the version is available to the public or if it is privately accessed by the owner
NOT NULL
state_id Int8 The identifier of the database state to which this version points
NOT NULL
description Varchar(65) An optional text description of the version
parent_name Varchar(64) The name of this version's parent version
parent_owner Varchar(32) The name of the owner of the parent version
parent_version_id Int The identifier of the version which is the parent of this version
creation_time Datetime The date/time that this version was created
NOT NULL
