Choosing the look and feel of the application
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
After choosing layers and tasks, you'll set the supporting details for the application such as title, links, and which map elements to display.
Two panels of Manager assist you in configuring the look and feel of your application. The first allows you to set the page properties, namely the title text, theme, and links to external Web sites. The second panel includes a list of map elements that you can enable and configure for the application.
You can access these panels while either creating a new Web application or editing an existing application in Manager.
How to set the page properties
  1. Ensure that you are on the Set Page Properties panel of Manager, as explained above.
  2. Type the title text for your application. This is the text that users will see on the top banner of the application. This text will also appear in the Web browser's title bar.
  3. Choose one of the predefined themes for your application.
  4. Choose which links you want to appear on the top banner of the application. If you want to add your own link, click Add link and type a name and the complete URL of the site you want to link to.
  5. When you've finished setting the page properties, click Next to view the panel for enabling and configuring map elements.
How to enable and configure the map elements
  1. Ensure that you are viewing the Enable Map Elements panel of Manager, as explained above.
  2. Uncheck the boxes next to any map elements you want to disable. All of the elements are enabled by default.
  3. If you want to further configure the settings for a map element, click its Settings button. A panel of options will appear for the element, which you can set to customize the way the element looks and behaves.
The following list defines the available map elements and provides tips for configuring each:
Next topic: Deploying the application
