Code example for stopping and starting services
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
using System;
using System.Collections.Generic;
using System.Text;
using ESRI.ArcGIS.esriSystem;
using ESRI.ArcGIS.Server;
namespace arcgisservice
    class Program
        static void Main(string[] args)
            GISServerConnection connection = null;
            IServerObjectAdmin3 soa = null;
            try
                connection = new GISServerConnection();
                connection.Connect(args[0]);
            catch (Exception e)
                Console.WriteLine("Could not connect to server. Make sure this user is a member of the AGSADMIN group.");
                Console.WriteLine(e.StackTrace);
                usage();
            try
                soa = (IServerObjectAdmin3)connection.ServerObjectAdmin;
                if (String.Compare(args[3], "stop") == 0)
                    soa.StopConfiguration(args[1], args[2]);
                else if (String.Compare(args[3], "start") == 0)
                    soa.StartConfiguration(args[1], args[2]);
                else
                    Console.WriteLine("No recognizable command.  Choose from [stop | start].");
                    usage();
            catch (Exception e)
                Console.WriteLine("Error connecting to service. The service or service type does not exist. Check your case and spelling.");
                usage();
        static void usage()
            Console.WriteLine("Usage: arcgisservice [serverName] [serviceName] [serviceType] [start | stop]");
            Console.WriteLine("     Example: arcgisservice myServer myService MapServer stop");
            Environment.Exit(-1);
