ArcGIS Server Banner
ST_Difference
ST_Difference
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_Difference takes two geometry objects and returns a geometry object that is the difference of the source objects.
Syntax
Oracle
sde.st_difference (g1 sde.st_geometry, g2 sde.st_geometry)
PostgreSQL
st_difference (g1 st_geometry, g2 st_geometry)
Return type
ST_Geometry
Example
The city engineer needs to know the total area of the city's lot area not covered by buildings. In fact, she wants the sum of the lot area after the building area has been removed.
Oracle
CREATE TABLE footprints (building_id integer,
footprint sde.st_geometry);
CREATE TABLE lots (lot_id integer,
lot sde.st_geometry);
INSERT INTO footprints (building_id, footprint) VALUES (
1,
sde.st_polygon ('polygon ((0 0, 0 10, 10 10, 10 0, 0 0))', 0)
2,
sde.st_polygon ('polygon ((20 0, 20 10, 30 10, 30 0, 20 0))', 0)
3,
sde.st_polygon ('polygon ((40 0, 40 10, 50 10, 50 0, 40 0))', 0)
INSERT INTO lots (lot_id, lot) VALUES (
1,
sde.st_polygon ('polygon ((-1 -1, -1 11, 11 11, 11 -1, -1 -1))', 0)
2,
sde.st_polygon ('polygon ((19 -1, 19 11, 29 9, 31 -1, 19 -1))', 0)
3,
sde.st_polygon ('polygon ((39 -1, 39 11, 51 11, 51 -1, 39 -1))', 0)
PostgreSQL
footprint st_geometry);
lot st_geometry);
1,
2,
3,
1,
2,
3,
The city engineer equijoins the footprints and lots table on the lot_id and takes the sum of the area of the difference of the lots minus the footprints.
Oracle
SELECT SUM (sde.st_area (sde.st_difference (lot, footprint)))
FROM footprints bf, lots
WHERE bf.building_id = lots.lot_id;
SUM(ST_AREA(ST_DIFFERENCE(LOT,FOOTPRINT)))
114
PostgreSQL
SELECT SUM (st_area (st_difference (lot, footprint)))
sum
114
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial operations
