ArcGIS Server Banner
ST_GeomFromShape
ST_GeomFromShape
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
NOTE: Spatial type for PostgreSQL only
Definition
ST_GeomFromShape constructs a geometry from an ESRI shape.
Syntax
st_geomfromshape (esri_shape bytea, srid integer)
Return type
ST_Geometry
Example
The following example inserts a record into the geoshape table with an ID and two geometry columns.
CREATE TABLE geoshape (id integer, g1 st_geometry, g2 bytea);
The INSERT statements insert the data into the columns of the geoshape table. The SELECT statement at the end ensures data was inserted into the g1 column.
INSERT INTO geoshape (id, g1) VALUES (
1,
st_geometry ('point (10 10)', 0)
2,
st_geometry ('linestring (10 10, 20 20, 30 30)', 0)
UPDATE geoshape
SET g2 = st_asshape (g1)
WHERE id = 1;
UPDATE geoshape
WHERE id = 2;
SELECT id, st_astext (st_geomfromshape (g2, 0))
FROM geoshape;
id    st_astext
1	POINT ( 10 10)
2	LINESTRING ( 10 10, 20. 20, 3 30)
See Also
  • An overview of SQL functions used with ST_Geometry types
