ArcGIS Server Banner
ST_GeomFromWKB
ST_GeomFromWKB
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_GeomFromWKB takes a well-known binary (WKB) representation and a spatial reference ID to return a geometry object.
Syntax
Oracle
sde.st_geomfromwkb (wkb blob, srid integer)
PostgreSQL
st_geomfromwkb (wkb, srid integer)
st_geomfromwkb (esri_shape bytea, srid integer)
Return type
ST_Geometry
Example
In the following example, the lines of results have been reformatted for readability. The spacing in your results will vary according to your online display. The following code illustrates how the ST_GeomFromWKB function can be used to create and insert a line from a WKB line representation. The following example inserts a record into the sample_geometries table with an ID and a geometry in spatial reference system 1 in a WKB representation.
Oracle
CREATE TABLE sample_geometries (id integer, geometry sde.st_geometry, wkb blob);
INSERT INTO sample_geometries (id, geometry) VALUES (
1901,
sde.st_geomfromtext ('point (1 2)', 0)
1902,
sde.st_geomfromtext ('linestring (33 2, 34 3, 35 6)', 0)
1903,
sde.st_geomfromtext ('polygon ((3 3, 4 6, 5 3, 3 3))', 0)
UPDATE sample_geometries
SET wkb = sde.st_asbinary (geometry)
WHERE id = 1901;
WHERE id = 1902;
WHERE id = 1903;
SELECT id, sde.st_astext (sde.st_geomfromwkb (wkb, 0))
FROM sample_geometries;
ID   GEOMETRY
1901 POINT (1.00000000 2.00000000)
1902 LINESTRING (33.00000000 2.00000000, 34.00000000 3.00000000, 35.00000000 6.00000000)
1903 POLYGON ((3.00000000 3.00000000, 5.00000000 3.00000000, 4.00000000 6.00000000, 3.00000000 3.00000000))
PostgreSQL
CREATE TABLE sample_geometries (id integer, geometry st_geometry, wkb bytea);
1901,
st_geometry ('point (1 2)', 0)
1902,
st_geometry ('linestring (33 2, 34 3, 35 6)', 0)
1903,
st_geometry ('polygon ((3 3, 4 6, 5 3, 3 3))', 0)
SET wkb = st_asshape (geometry)
WHERE id = 1901;
WHERE id = 1902;
WHERE id = 1903;
SELECT id, st_astext (st_geomfromshape (wkb, 0))
id   st_astext
1901 POINT (1 2)
1902 LINESTRING (33 2, 34 3, 35 6)
1903 POLYGON ((3 3, 5 3, 4 6, 3 3))
See Also
  • An overview of SQL functions used with ST_Geometry types
