ArcGIS Server Banner
ST_IsEmpty
ST_IsEmpty
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_IsEmpty returns 1 (Oracle) or t (PostgreSQL) if the geometry is empty; otherwise, it returns 0 (Oracle) or f (PostgreSQL).
Syntax
Oracle
sde.st_isempty (g1 sde.st_geometry)
PostgreSQL
st_isempty (g1 st_geometry)
Return type
Boolean
Example
The CREATE TABLE statement below creates the empty_test table with geotype, which stores the data type of the subclasses that are stored in the g1 ST_Geometry column.
The INSERT statements insert two records for the geometry subclasses point, linestring, and polygon: one that is empty and one that is not.
Oracle
CREATE TABLE empty_test (geotype varchar(20), g1 sde.st_geometry);
INSERT INTO empty_test VALUES (
'Point',
sde.st_pointfromtext ('point (10.02 20.01)', 0)
'Point',
sde.st_pointfromtext ('point empty', 0)
'Linestring',
sde.st_linefromtext ('linestring (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
'Linestring',
sde.st_linefromtext ('linestring empty', 0)
'Polygon',
sde.st_polyfromtext ('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
19.15 33.94, 10.02 20.01))', 0)
PostgreSQL
CREATE TABLE empty_test (geotype varchar(20), g1 st_geometry);
'Point',
st_point ('point (10.02 20.01)', 0)
'Point',
st_point ('point empty', 0)
'Linestring',
st_linestring ('linestring (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
'Linestring',
st_linestring ('linestring empty', 0)
'Polygon',
st_polygon ('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
The SELECT query returns the geometry type from the geotype column and the results of the ST_IsEmpty function.
Oracle
SELECT geotype, sde.st_isempty (g1) Is_it_empty
FROM empty_test;
GEOTYPE    Is_it_empty
Point         0
Point         1
Linestring    0
Linestring    1
Polygon       1
PostgreSQL
SELECT geotype, st_isempty (g1) AS Is_it_empty
FROM empty_test;
geotype   is_it_empty
Point         f
Point         t
Linestring   f
Linestring    t
Polygon       f
See Also
  • An overview of SQL functions used with ST_Geometry types
