ArcGIS Server Banner
ST_Polygon
ST_Polygon
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_Polygon generates an ST_Polygon from a well-known text (WKT) representation and a spatial reference ID (SRID).
Syntax
Oracle
sde.st_polygon (wkt clob, srid integer)
PostgreSQL
st_polygon (wkt, srid integer)
st_polygon (esri_shape bytea, srid integer)
Return type
ST_Polygon
Example
The following CREATE TABLE statement creates the polygon_test tables, which have a single column, p1. Then the INSERT statement converts a ring (a polygon that is both closed and simple) into an ST_Polygon and inserts it into the p1 column using the ST_Polygon function.
Oracle
CREATE TABLE polygon_test (p1 sde.st_geometry);
INSERT INTO polygon_test VALUES (
sde.st_polygon ('polygon ((10.01 20.03, 20.94 21.34, 35.93 10.04, 10.01
20.03))', 0)
PostgreSQL
CREATE TABLE polygon_test (p1 st_geometry);
20.03))', 0)
See Also
  • An overview of SQL functions used with ST_Geometry types
