ArcGIS Server Banner
ST_Touches
ST_Touches
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_Touches returns 1 (Oracle) or t (PostgreSQL) if none of the points common to both geometries intersect the interiors of both geometries; otherwise, it returns 0 (Oracle) or f (PostgreSQL). At least one geometry must be an ST_LineString, ST_Polygon, ST_MultiLineString, or ST_MultiPolygon.
Syntax
Oracle
sde.st_touches (g1 sde.st_geometry, g2 sde.st_geometry)
PostgreSQL
st_touches (g1 st_geometry, g2 st_geometry)
Return type
Boolean
Example
The GIS technician has been asked by his boss to provide a list of all sewer lines that possess endpoints that intersect another sewer line.
The sewerlines table is created with three columns. The first column, sewer_id, uniquely identifies each sewer line. The integer class column identifies the type of sewer line generally associated with the line's capacity. The sewer ST_Linestring column stores the sewer line's geometry.
Oracle
CREATE TABLE sewerlines (sewer_id integer,
sewer sde.st_geometry);
INSERT INTO sewerlines VALUES (
1,
sde.st_mlinefromtext ('multilinestring ((20 30, 30 30, 30 40, 20 40, 20 30))', 0)
2,
sde.st_mlinefromtext ('multilinestring ((30 30, 30 50, 50 50, 50 30, 30 30))', 0)
3,
sde.st_mlinefromtext ('multilinestring ((40 40, 40 60, 60 60, 60 40, 40 40))', 0)
4,
sde.st_linestring ('linestring (60 60, 70 70)', 0)
5,
sde.st_linestring ('linestring (30 30, 60 60)', 0)
PostgreSQL
sewer st_geometry);
1,
st_multilinestring ('multilinestring ((20 30, 30 30, 30 40, 20 40, 20 30))', 0)
2,
st_multilinestring ('multilinestring ((30 30, 30 50, 50 50, 50 30, 30 30))', 0)
3,
st_multilinestring ('multilinestring ((40 40, 40 60, 60 60, 60 40, 40 40))', 0)
4,
5,
The query returns an ordered list of sewer IDs that touch one another.
Oracle
SELECT s1.sewer_id, s2.sewer_id
FROM sewerlines s1, sewerlines s2
WHERE sde.st_touches (s1.sewer, s2.sewer) = 1;
  SEWER_ID   SEWER_ID
         1          5
         3          4
         4          3
         4          5
         5          1
         5          3
         5          4
PostgreSQL
WHERE st_touches (s1.sewer, s2.sewer) = 't';
  SEWER_ID   SEWER_ID
         1          5
         3          4
         4          3
         4          5
         5          1
         5          3
         5          4
See Also
  • An overview of SQL functions used with ST_Geometry types
  • Spatial relationships
