ArcGIS Server Banner
ST_Z
ST_Z
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Definition
ST_Z can take an ST_Point as an input parameter and return its z (elevation)-coordinate.
Syntax
Oracle
sde.st_z (g1 sde.st_point)
PostgreSQL
st_z (g1 st_point)
Return type
Number (Oracle), integer (PostgreSQL)
Example
The z_test table is created with two columns: the id column, which uniquely identifies the row, and the geometry point column. The INSERT statement inserts a row into the z_test table.
Oracle
CREATE TABLE z_test (id integer unique, geometry sde.st_point);
INSERT INTO z_test (id, geometry) VALUES (
1,
sde.st_point (2, 3, 32, 5, 0)
PostgreSQL
CREATE TABLE z_test (id integer unique, geometry st_point);
1,
The SELECT statement lists the id column and the double-precision z-coordinate of the point inserted with the previous statement.
Oracle
SELECT id, sde.st_z (geometry) Z_COORD
FROM z_test;
        ID      Z_COORD
         1        32
PostgreSQL
SELECT id, st_z (geometry) AS Z_COORD
FROM z_test;
        id      z_coord
         1        32
See Also
  • An overview of SQL functions used with ST_Geometry types
