Logging in to Manager
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
You can open Manager by browsing to the Start Menu shortcut (Start > All Programs > ArcGIS > ArcGIS Server for the Java Platform > Manager). Alternatively, you can just enter Manager's URL in a web browser. The URL for Manager is http://<server name>:8099/arcgismanager/main/login.jsf
When you open Manager, you will be prompted to log in. You must use an account that is
You will notice that the name of the ArcGIS Server machine cannot be changed in the login screen. This is because Manager is directly associated with one instance of ArcGIS Server. Specifically, the GIS server is the machine running the SOM component of ArcGIS Server.
Securing your login credentials
When you log in to Manager with the default shortcut, the name and password are sent to the server in clear text. For working with Manager outside your local machine, it's recommended that you run Manager using Secure Sockets Layer (SSL), which encrypts all communication between Manager and the server.
If you run Manager under SSL, be sure to change the Manager shortcut to use https instead of http. To do this, right-click the shortcut, click Properties, then modify the target URL so that it begins with "https".
