Preparing resources for publishing as services
Release 9.3 E-mail This Topic Printable Version Give Us Feedback
Before publishing a service, you need to create the GIS resource that the service will reference. For a full list of GIS resources that can be published as services, see What types of services can you publish?. Most GIS resources require that you use ArcGIS Desktop to create them.
When you first create a GIS resource, you'll save it on your local file system. Client applications will not be able to view the resource until you publish it as a service.
In many ways, creating a resource that will be used in a service is no different than creating an ordinary resource; you use the appropriate application, such as ArcMap, to select data for the resource and set your preferred properties. However, if you know that a resource will be published as a service, you'll want to follow these extra guidelines:
Store your data in a way that all SOC machines can access it
Each server object container (SOC) machine in your ArcGIS Server deployment needs to be able to access your GIS resource and all the data it contains. For example, when you publish a map document as a service, the map document and all the data for its layers must be accessible to all SOC machines.
When you save your data to a local path, for example, C:\data or "/opt/local/data" on Linux/Solaris, and create a service from it, other SOC machines will not be able to work with the service unless they have their own copies of the data residing at C:\data or "/opt/local/data" on Linux/Solaris. Although loading an identical copy of your data into an identical path on each SOC machine can be beneficial for performance, it is not a practical solution for large or frequently changing datasets.
The easiest way to make one copy of your data available to all SOC machines is to use the operating system tools to share the directory in which the data is stored. Shared directories are commonly referred to with Universal Naming Convention (UNC) paths or NFS mounted folders on Linux/Solaris, which contain the name of the server (for example, \\myServer\data or /net/myserver/opt/local/data). When you use UNC paths or NFS paths to reference your data, all SOC machines will look to the correct machine for the data.
If you store your GIS resources in shared directories, remember that all data source paths within the resource must also use UNC paths, NFS paths or relative paths. For example, if your map document contains layers from three feature classes, the paths to those feature classes must be UNC paths, NFS paths or relative paths.
Give the SOC account permissions to your data
When you log in to your own computer, the account name you use gives you access to all your files and folders on the computer. No one else can access your data unless you allow them to. The same holds true for your GIS data. For the GIS server--or more specifically, the SOC machines--to access your data, you must grant the SOC user account (On Windows, you specified during the GIS Server Post Install; on Linux/Solaris, the SOC account is the same as the GIS server install owner account) access to it. Most likely, if you work for a large organization, your GIS data won't be stored on your local computer but instead will be stored on a shared network drive or in a geodatabase. However, the same principles of granting the SOC account access to the data apply.
Setting up access to file-based data
If your data is file based, such as shapefiles and coverages, you'll need to work with the operating system to set access to the folders that contain your data. The SOC account must have read access to the data. Here are some possible scenarios:
Setting up access to data in a geodatabase
When you create a service that references data in a geodatabase, you need to ensure that the server has the appropriate permissions to access the geodatabase. The type of permissions you need to grant depends on what type of geodatabase you are using and, in the case of ArcSDE, what type of authentication you are using to connect.
If your service accesses data from a file geodatabase or personal geodatabase (Note: personal geodatabase data source does NOT work for Linux/Solaris GIS Server), you should use the operating system to give the SOC account read permissions to the folder containing the geodatabase.
The way you grant access to an ArcSDE geodatabase depends on whether your GIS resource uses database authentication or operating system (OS) authentication to connect to ArcSDE. How can you tell which type of authentication is being used? If the geodatabase is in SQL Server Express, it uses OS authentication. If the geodatabase is in an enterprise RDBMS (Oracle, SQL Server, DB2, Informix), you can view the Connection Properties in ArcCatalog to find out whether it uses database authentication or OS authentication.
Note: Joins that use ODBC connections on Windows are NOT supported by ArcGIS Server on Linux/Solaris.
Using database authentication
When using database authentication, check your Spatial Database Connection properties in ArcCatalog and make sure you've checked the option to save the user name and password. If you create a map or globe document that uses data through that connection, the name and password will be saved in the map or globe document, and your service should be able to get the data successfully.
If you are publishing something as a service directly from the geodatabase, such as a toolbox, locator, or raster dataset, be sure to use an unambiguous connection file to reference the data. This means that you copy the connection file to a shared network directory and reference your data in the service properties through a UNC path or NFS path.
Using OS authentication
If your ArcSDE data will be accessed through OS authentication, you'll need to add the SOC account to the geodatabase, then grant it permissions to the resource that it needs to access. When the service runs, it will log in to the DBMS as the SOC account. The way that you add the SOC account and grant it permissions varies depending on what type of ArcSDE geodatabase you are using:
Follow best practices specific to the resource you're creating
Most types of resources have a list of best practices you can follow when preparing the resource for publishing as a service. For example, creating a cache, using scale-dependent renderers, or simplifying label placement preferences are things you can do to help your map services run faster. This help system contains a dedicated topic for each type of service you can create. See these topics for additional best practices.
