What's new in ArcIMS 9.2 expand/collapse all
expand/collapse item What's new in ArcIMS 9.2
ArcIMS 9.2 is a major release with new functionality. The following is a summary of these changes.
Web Manager
ArcIMS introduces a Web Manager for creating Web applications. The Web Manager provides step-by-step instructions that guide you through the application building process.
The output is a Web Mapping Application that can be deployed immediately. The Web Mapping Application uses current technology such as AJAX, and includes seamless panning, scroll-wheel zoom, keyboard navigation, and a fully functional table of contents with swatches, among other new features.
The Web Manager comes in two versions:
Web ADF
ArcIMS includes a Web Application Developer Framework (Web ADF). Like Web Manager, the Web ADF is available for the Microsoft .NET Framework and for the Java Platform.
When using the Web ADF, you can work with Image and ArcMap Image Services, ArcGIS Server services, ArcWeb services, and WMS services. The same Web ADF can be used with both ArcIMS and ArcGIS Server.
As a developer, you have access to a full set of mapping-related Web controls and an API that wraps ArcXML functionality. Since the Web Mapping Application is built using these components, you can take the output from Web Manager into an Integrated Development Environment (IDE) and modify the output. You can also use the Web controls and build your own application from scratch.
The Web ADF includes comprehensive online support via the ESRI Developer Network (EDN), including Getting Started guides, detailed API discussions, Scenarios and Samples, and Library References.
Web ADF for the Microsoft .NET Framework
The .NET 2.0 framework is required. Visual Studio 2005 or Visual Studio Web Express Edition must be installed to work with the Web controls and templates.
The Web ADF also includes a .NET ArcIMS API, which replaces the .NET Link. The API has an object model that comprehensively wraps all ArcXML functionality. The exception at ArcIMS 9.2 is that Metadata elements are not part of the API.
Web ADF for the Java Platform
The Web ADF for the Java Platform uses Java Server Faces (JSF), which provides the framework for the Web controls and tasks. The Web ADF uses the Java Connector for communication with ArcIMS services. While developers can use any IDE that supports JSF, the recommended IDE's are Eclipse or Sun Studio Creator.
For those who use Metadata Services, a new, ready-to-use Metadata Explorer application based on the Web ADF for the Java Platform is provided for accessing Metadata Services.
Documentation and online help
Spatial Server
The Spatial Server has been updated to improve performance and stability. The following enhancements have been made.
  • When using Extract Server, if there are no layers to extract in a request, an error message is returned instead of returning an empty zip file.
  • Support has been added for new geocoding styles: World Cities with Country, US Cities with State and US Streets with City, State and Zip. For more information, see Adding geocode parameters to the geocode extension
  • Administrator
    Author
    Metadata Services
    WMS Connector
    WFS Connector
    ArcXML
    Internationalization/localization
    Installation notes
    Platform, Web server, and servlet engine updates
    For a list of all supported platforms, servlet engines, and Web servers, see System Requirements for ArcIMS.
    Deprecation Notes
    As ArcIMS adds new features and functionality, older components are marked for deprecation. Deprecation means that a particular feature is completely supported but may be removed in a future release. Features are not normally removed from ArcIMS unless there is a new feature to replace it.
    Features deprecated in ArcIMS 9.2
    The following features are marked as deprecated in ArcIMS 9.2. They continue to be fully supported; however, they may be removed in a future release:
    Features removed from ArcIMS 9.2
    Search code: @what_new_in_arcims_92
