Creating and changing your password expand/collapse all
Related Topics
Starting ArcIMS Administrator and Service Administrator
expand/collapse item About creating and changing your password
When you open ArcIMS Administrator or Service Administrator, use command line administration, or open ArcIMS Web Manager for the Java Platform, you must provide a user name and password. You set the username and password the first time you open ArcIMS Administrator or Service Administrator. You must set the username and password in either of these two applications before you can use command line administration or login to ArcIMS Web Manager for the Java Platform. (If you are using ArcIMS Web Manager for the Microsoft .NET Framework, you log in using a user account on your machine).
You can change both the user name and password at a later time in Administrator. Although you need a user name and password to access Service Administrator, you cannot change them in this application.
Your password information is stored in a file named AimsAdmPw. If you forget your password, you can delete this file and restart ArcIMS. When you next open Administrator or Service Administrator, you will be prompted for a new user name and password.
expand/collapse item How to create and change passwords
expand/collapse item Creating your username and password the first time
  1. Open Administrator or Service Administrator. If this is the first time logging in, you will see a place to type a new username, password, and password confirmation.
  2. Add values for User Name, New Password, and Confirm Password.
    User names and passwords cannot contain spaces or vertical bars.
  3. Click OK.
expand/collapse item Changing your password using ArcIMS Administrator
  1. In the Administrator menu, click Change Login.
  2. Type a new user name and password.
  3. Type your password again to confirm it.
  4. Click OK.
expand/collapse item Changing your password by working with the AimsAdmPw file
  1. Search for the file named AimsAdmPw in the Application Server directory.
    Windows: <ArcGIS Installation Directory>\ArcIMS\AppServer
    UNIX or Linux: $AIMSHOME/Middleware/Application_Server
  2. Delete AimsAdmPw.
  3. Restart ArcIMS Monitor and ArcIMS Application Server.
    The next time you open Administrator or Service Administrator, you will be prompted for a new user name and password.
expand/collapse item Tips for choosing safe passwords
Choose a password that:
Search code: @admin_password
