Setting site properties expand/collapse all
Related Topics
aimsdefaults.properties reference for Administrator, Designer, and Author
sitePreferences.properties reference for Site Administrator
expand/collapse item About site properties
The site properties for your ArcIMS site can be set in the Site Properties dialog in Administrator and in the Configure Site tab of Service Administrator. The site properties can be changed at any time. The following properties are available in both Administrator and Service Administrator:
The following properties are specific to Administrator:
Service Administrator also has some additional properties in its dialog:
Property files
The properties you set are saved to a property file. For Service Administrator, the properties are saved to a file named sitePreferences.properties located in the ArcIMS installation AppServer directory. You should not need to directly modify this file. Any changes to the site properties should be made using Service Administrator.
For Administrator, the property file is named aimsdefaults.properties and is located in your user profile directory. This property file is used for Administrator, Author, Designer, and launching the Help system. Some of the properties are not available through the dialog in Administrator, and the property file must be edited. The properties are:
expand/collapse item How to set site properties
expand/collapse item Setting site properties in Administrator
  1. Click the View menu, and click Site Properties to open the Site Properties dialog box.
  2. Type the name of the host computer.
  3. Type the URL location of the host computer.
  4. Type or navigate to the Web site directory.
  5. Click the Server Output tab.
  6. Type or navigate to the location of the output directory.
  7. Type the URL location of the output directory.
  8. Set the server cleanup interval.
    Click to the left or right of the slider to change the server cleanup interval by six-minute increments. Drag the slider right or left to change the server cleanup interval by one minute increments.
  9. Select a value for the Image Memory Limit.
  10. Click OK to apply your changes and to close the Site Properties dialog box.
Note: the alias feature is not valid. Any changes you make will be ignored.
expand/collapse item Setting site properties using Service Administrator
  1. Click the Configure Site tab. The Default Site Properties panel appears.
  2. Type the path to the output directory.
  3. Type the HTTP location of the output directory in the Output URL text box.
  4. Click the Clean Up Interval dropdown arrow and click a clean-up interval.
  5. Click the Image Memory Size dropdown arrow and click the maximum memory limit.
  6. Click the Default Image Format dropdown arrow and click an image format.
  7. Click the Prompt to Save Startup File dropdown arrow and click Yes or No. If you click Yes, you will be prompted every time you make a change to the site configuration.
  8. Click the Automatic Save Startup File dropdown arrow and click Yes or No. If you click Yes, changes to the site configuration are saved automatically.
  9. Click Update.
expand/collapse item Setting properties in aimsdefaults.properties
  1. In a text editor, open aimsdefaults.properties.
    Windows: <Drive>:\Documents and Settings\<user account>
    UNIX: $HOME
  2. Find the IndexBuilderEXE property. Change the path to a new value. Follow the syntax for your platform for the path name.
  3. Find the WebBrowser property. Change the path to a new value. Follow the syntax for your platform for the path name.
Search code: @admin_site
