Working with MapNotes expand/collapse all
Related Topics
Working with Folders in Administrator
expand/collapse item About MapNotes
The MapNotes tools allow you to share ideas about data over the Internet. Use the MapNotes tools to add text or graphics about a map to a MapNotes layer, then submit your notes to ArcIMS Administrator. The MapNotes toolbar contains a full suite of tools to add, delete, and change the appearance of the notes that you create.
You can create more than one MapNotes layer during a single MapNotes session, but the total size of your MapNotes submission cannot be more than 100 KB. If you have many notes to submit, you must submit them in different sessions or the ArcIMS site administrator must increase the submission limit.
When you click the MapNotes button, the MapNotes toolbar appears. Existing MapNotes layers created by you or other users are automatically loaded. Use the following tools to create and edit MapNotes layers. When you are done, submit your MapNotes. A MapNotes item will appear in Administrator's MapNotes folder with a time stamp and description. After you have submitted your layer, others accessing the same Internet GIS application will also be able to see the MapNotes layer you created.
The description of a MapNotes layer can be viewed by others using the MapNotes and is listed, along with the MapNotes layer name, in ArcIMS Administrator. See Working with Folders in Administrator to see a listing of submitted MapNotes using ArcIMS Administrator.
MapNotes has been deprecated and may not be available in a future release.
MapNotes toolbar
MapNotes toolbar
New MapNotes Layer: Creates a new MapNotes layer.
Select MapNotes Layer: Makes your chosen layer the active layer.
Delete MapNotes Layer: Deletes the current MapNotes layer from the list of available layers.
Description: Opens a dialog box in which you can type a description of the MapNotes layer.
Submit: Submits the current MapNotes session to ArcIMS Administrator.
Stop: Stops your MapNotes session and closes the MapNotes toolbar.
Undo: Removes the most recently added text or graphic from the layer.
Redo: Reintroduces text or graphics that were removed using the Undo button.
Select MapNote: Selects the text or graphic item that you click.
Add Point: Adds a point to the layer.
Add Line: Adds a line to the layer.
Add Polygon: Adds a polygon to the layer.
Add Rectangle: Adds a rectangle to the layer.
Add Circle: Adds a circle to the layer.
Add Text: Adds text and allows you to change the font style and color.
Add Image : Adds an image to the layer.
Add Freehand: Adds a freehand line to the layer.
Delete MapNote: Deletes the selected text or graphic item from the MapNotes layer.
expand/collapse item How to work with MapNotes
expand/collapse item Creating a new MapNotes layer
  1. Click MapNotes on the toolbar.
  2. Click New MapNotes layer on the MapNotes toolbar.
  3. Type a name for the new layer in the dialog box that appears (Java Custom Viewer), OR highlight the default name in the dropdown box and type a new name (Java Standard Viewer).
  4. Click the Description button and type a description of the layer. Click OK to finish.
  5. Add MapNotes Features.
    • Click the Add Point button and click the map.
    • Click the Add Circle or Add Rectangle button and drag a graphic on the map.
    • Click the Add Line or Add Polygon button and draw a multipoint line or polygon on the map.
      When you are finished creating a line, freehand line or text, or polygon, double-click the map to complete your graphic.
    • Click the Add Freehand button to draw a freehand line on the map.
    • Click Add Image and navigate to the image file.
      After you have navigated to an image, add it to the map by clicking the location where you want it.
    • Click Text and type the text to add. Click the Font button to set text properties.
      After you have set text properties, add the text to the map by clicking the location where you want it.
  6. Click the Submit button to submit your MapNotes session.
expand/collapse item Editing an existing MapNotes layer
  2. Select a MapNotes Layer.
    Java Custom Viewer: Click the Select MapNotes Layer button on the MapNotes toolbar. Click a layer in the dropdown list on the dialog box that appears then click Select.
    Java Standard Viewer: Click the dropdown arrow on the MapNotes toolbar and click a layer.
  3. Add text and graphics as you would when creating a New MapNotes layer.
  4. Delete text and graphics by clicking the Select MapNote tool, then clicking text or graphics on the map. Click the Delete MapNote button.
  5. Click the Submit button to submit your changes.
expand/collapse item Tips
Undo and Redo
If you made a mistake and want to undo it, click the Undo button. If you undid something and want to put it back to the way it was, click the Redo button.
Switching to another tool
The MapNotes toolbar will close if you click another tool on the Java Custom Viewer toolbar. To reopen the MapNotes toolbar, click the MapNotes button.
Selecting a MapNotes layer
As an alternative to selecting MapNotes layers from a dropdown list, you can select layers interactively. Click the Select MapNotes Layer in the Java Standard Viewer or Select MapNotes Layer from Map in the Java Custom Viewer, then click the MapNotes icon on the map.
Search code: @java_mapnotes
