Changing image output parameters expand/collapse all
Related Topics
aimsms.cfg reference for Image Server
expand/collapse item About the image output parameters
You can change some settings for image output and display for images generated from an Image Service. Depending on the type of data you have, along with requirements for quality, you may want to change some Spatial Server parameters. Because each site is unique, an image setting that performs well for one site may not work as well for another site.
Changing JPEG quality
The parameter jpegquality can be modified to change the quality of the JPEG output. The value represents a percentage value from 0 to 100, where 0 is the lowest quality and 100 is the best (default is 85 percent). The higher the value, the longer it takes to generate the image. This value does not signify the amount of compression.
The following table shows output file size and output generation time based on the JPEG quality setting. The output generation time is available in the Image Server log files. This benchmark is based on an image 800 x 600 with six vector layers. The file size and output time should be considered relative to each other since results will vary depending on the size and type of data used in a map.
jpegquality Image size (kb) Output time (sec)
50 146 0.047
60 164 0.047
70 189 0.047
85 (default) 256 0.062
90 304 0.078
100 668 0.078
Changing the PNG compression
The parameter pngcompression is a compression value from 0 to 9, where 0 indicates no compression and 9 indicates the highest compression. The higher the compression, the longer it takes to generate an image. The default value of -1 is equivalent to a compression value of 6.
The following table shows output file size and output generation time based on the PNG compression setting. This benchmark is based on the same 800 x 600 image with six vector layers used for the JPEG benchmark. The file size and output time should be considered relative to each other.
pngcompression PNG8 Image size (kb) PNG8 Output time (sec) PNG24 Image size (kb) PNG24 Output time (sec)
0 471 0.047 1410 0.109
1 70 0.032 110 0.109
2 63 0.047 100 0.109
3 56 0.063 88 0.137
4 54 0.062 80 0.141
5 48 0.062 74 0.156
6, -1 (default) 45 0.094 67 0.203
7 44 0.140 67 0.219
8 41 0.359 66 0.453
9 41 0.766 63 1.22
Changing the type of GIF output
The parameter interlacedgif specifies whether the images are interlaced or non-interlaced. An interlaced GIF first appears in a pixilated form before the higher resolution image is displayed. It provides an early cue to your user that an image is on the way. This setting does not affect performance. The output size and generation time, whether interlaced or not, is entirely dependent on the data source.
True = interlaced (default).
False = no interlacing.
expand/collapse item How to change image output parameters
expand/collapse item Changing image output parameters
  1. In a text editing application, open aimsms.cfg file.
    Windows: <ArcGIS Installation Directory>\ArcIMS\Server\etc
    UNIX and Linux: $AIMSHOME/etc
  2. Locate the jpgquality attribute in the PARAMETERS section.
  3. <PARAMETER name="jpgquality" value="85" />
    Specify a new quality value from 0 to 100. The default is 85.
  4. Locate the pngcompression attribute in the PARAMETERS section.
  5. <PARAMETER name="pngcompression" value="-1" />
    Specify a new compression value from 0 to 9. The default is -1 or 6.
  6. Locate the interlacedgif attribute in the PARAMETERS section.
  7. <PARAMETER name="interlacedgif" value="true" />
    Specify true or false. The default is true.
  8. Restart ArcIMS Monitor and ArcIMS Application Server.
Search code: @stability_image
