The GPS Position Window |
| Release 8 |
The GPS Position window displays a rich variety of information about the GPS satellites, position coordinates, and navigational information. The information is spread across four tabs: Data, Skyplot, Compass and Quality.
Some of the display fields have context or tap menus; if you tap the field, a menu list will be displayed with alternative information or data formats, to be displayed in the associated field.
In the following example, the position coordinate display field has been tapped, using the cursor or stylus, to display the menu of coordinate systems. The current selection in the tap menu is indicated by a check mark to the left of the selection—for example, DMS in the screenshot below.
The GPS Position Window displays the following information:
The GPS Mode displays the type of position being calculated by the GPS receiver. There are three groups of GPS modes that can be displayed: NOFIX, 2D/3D, and differential modes.
NOFIX indicates that ArcPad is not receiving a position from the GPS receiver. No position coordinate will be displayed if the initial GPS Mode is NOFIX. Also, the 2D/3D or differential modes will not be displayed during the NOFIX mode.
2D indicates that only three satellites are available and are being used to calculate the x,y position coordinates. 3D indicates that at least four satellites are available and are being used to calculate the x, y, and z (elevation) position coordinates.
DGPS indicates that real-time differential correction is being used to calculate the x, y, and z position coordinates.
SBAS indicates that a real-time differential correction from a Satellite Based Augmentation System (SBAS) is being used to calculate the x, y, and z position coordinates. The Wide Area Augmentation System in the United States is an example of an SBAS real-time differential source.
RTK fix indicates that a real-time kinematic (RTK) fixed solution is being used to calculate the x, y, and z position coordinates.
RTK flt indicates that a real-time kinematic (RTK) float solution is being used to calculate the x, y, and z position coordinates.
PPS indicates that a Precise Positioning Service is being used.
Multiple GPS modes can be displayed simultaneously; for example, the 2D or 3D mode can be displayed simultaneously with the differential DGPS or PPS modes.
Position Coordinates is a tap and hold menu field; tapping and holding on the coordinates displays the following menu list of alternate coordinate systems, or projections, to be used for displaying the current GPS position:
Map Projection: the projection of the current map, which may be in latitude–longitude or UTM—or any other projection supported by ArcPad.
DMS: latitude–longitude in degrees, minutes and decimal seconds (ddd°mm’ss.ss”).
DMM: latitude–longitude in degrees and decimal minutes (ddd°mm.mmmm’).
DD: latitude–longitude in decimal degrees (ddd.ddddddddd°).
UTM: the current UTM (Universal Transverse Mercator) coordinates and zone.
WGS84 DMS: latitude–longitude in degrees, minutes, and decimal seconds (ddd°mm’ss.ss”), using the WGS84 datum.
WGS84 DMM: latitude–longitude in degrees and decimal minutes (ddd°mm.mmmm’), using the WGS84 datum.
WGS84 DD: latitude–longitude in decimal degrees (ddd.ddddddddd°), using the WGS84 datum.
MGRS: The Military Grid Reference System coordinate.
Elevation is a tap menu field; tapping on the elevation displays the following menu list of altitude or depth units to show in the elevation field, as shown below
Altitude (Meters)
Altitude (Feet)
Depth (Meters)
Depth (Feet)
The depth information is obtained from the standard NMEA message $SDDPT which provides the depth below the transducer and the offset of the transducer to the water line. This NMEA message is typically output by marine GPS devices such as depth sounders.
The Navigation Information displays the following information:
SOG: Speed Over Ground, as calculated by the GPS. SOG is the actual speed the GPS receiver is moving over the ground.
COG: Course Over Ground, as calculated by the GPS. COG is the direction the GPS receiver is moving and corresponds to the direction of the black Compass arrow.
DST: The distance from the current GPS position to the selected destination. The DST is calculated by ArcPad.
BRG: The bearing from the current GPS position to the selected destination. The BRG corresponds to the red destination direction on the Compass. The BRG is calculated by ArcPad.
COG is also a tap and hold menu field that provides the option of displaying the COG in one of the following formats:
TCOG: True North Course Over Ground
MCOG: Magnetic North Course Over Ground
Position Measure of Quality is a tap menu field. Tapping on the Position Measure of Quality displays the following menu list of information to be displayed in the field:
PDOP: Position Dilution of Precision.
DOP: Horizontal Dilution of Precision.
VDOP: Vertical Dilution of Precision.
TDOP: Time Dilution of Precision.
HPE: Estimated Horizontal Position Error.
VPE: Estimated Vertical Position Error.
EPE: Estimated Position Error.
SATS: Satellites used in solution. The number of satellites used by the GPS receiver to calculate the GPS position.
DAGE: Differential data age. The age, in seconds, of the differential signal and correction used by the GPS receiver to differentially correct the GPS position.
DSID: Differential reference station ID. The ID of the differential reference station used by the GPS receiver.
The satellite skyplot and signal chart are shown on their own tab. The Satellite Skyplot shows the almanac of which satellites should be visible or available to the GPS receiver. Each satellite is uniquely coloured and the PRN (PseudoRandom Noise) number and position of each satellite is displayed.
Satellite use is distinguished by:
A Black outline for satellites available and used for calculating the GPS position.
Satellites available but not used are simply colored.
Grey satellites are unavailable.
The Satellite Skyplot view shows a bird’s-eye view of the position of each satellite according to the satellite almanac. The outer circle represents the horizon (north is up); the inner circle represents 45° above the horizon; and the center point represents what is directly overhead.
The Signal Chart shows a bar chart of the PRN numbers and relative signal strengths of the satellites in the almanac. A red bar indicates that the satellite is unavailable.
The compass is displayed on its own tab in the GPS position window along with important navigational information.
The Compass shows the GPS direction with a black arrow and the direction to the selected destination in red. The GPS direction corresponds to the COG (Course Over Ground) direction, and the direction to the destination corresponds to the BRG (bearing).
Bearing: Speed over ground (SOG), True North Course over ground (TCOG), distance (DST) and bearing (BRG) are also displayed on the Compass tab.
All of the quality parameters that you can choose to display on the data tab (in place of the default PDOP) are listed on the quality tab.
Shows the GPS data being received from GPS.
