Steps to create line features with a GPS |
| Release 8 |
The Add GPS Vertex and Add GPS Vertices Continuously buttons are enabled if the GPS is activated.
The vertices are drawn with a blue box and joined with a line using the current selection color.
At any time, tap and hold anywhere on the map to display the Capture menu. Refer to the Creating line features task for more information on the Capture menu. Use the Capture menu to create vertices at specified x,y coordinates or relative to the last vertex or the current GPS position. You can also delete the last vertex.
The Point/Vertex dialog box shows a progress bar, which counts down from the specified number of GPS positions to average until it reaches zero.
If you tap OK before the averaging is complete, a dialog box will display asking whether you want to terminate the GPS position averaging.
Tap the X button to cancel the capture of the vertex.
The Feature Properties dialog box, or custom edit form, is automatically displayed after the new line feature has been created.
For example, tap on the Value field for STREET_NAM to open the associated Value text box and type the street name value of “New”.
