With ArcPad, you work with several different types of files. Each file type plays a specific
role in ArcPad and is differentiated by a unique file extension.
The key file types include:
- Custom Default Configuration File (ArcPad.apx): This file is loaded by default each
time ArcPad starts and is saved in the My Documents\MyArcPad folder on your device. ArcPad.apx
can contain custom toolbars, forms, and system object event handlers. In addition, it can
contain other parameters that override the ArcPad default such as which toolbars are initially
visible when the application starts.
- ArcPad Favorites File (ArcPadFavorites.apx): This file is created when you select
tools on the favorites tab of the ArcPad Options dialog. To remove the favorites toolbar from
ArcPad you can simple delete (or rename) this file. It is saved in the My Documents\MyArcPad
- Global Bookmark File (ArcPadBookMarks.apx): This file contains spatial bookmarks that
can be used in ArcPad regardless of the current map. It is saved in the My Documents\MyArcPad
- ArcPad Preference File (ArcPadPrefs.apx): This file contains ArcPad default
parameters, such as GPS settings, default symbology, default file paths, and so on. It is saved
- ArcPad Layer Definition File (*.apl): Layer definitions are stored in a file
associated with a shapefile, with the same filename as the shapefile but with the extension
.apl. Layer definition files provide a way of developing customizations that are delivered and
loaded with data. Layer definition files may also contain custom symbology exported from ArcGIS
Desktop.
- ArcPad Map File (*.apm): An ArcPad map file, or map, stores a list of the map layers
for your ArcPad session. A map lists all of your feature layers together with their display
settings, including the extent of your map, color, and projection environment.
- ArcPad Graphics Layer file (*.apg): The ArcPad Graphics Layer file is an XML file
that can store text, points, lines, and polygons. It is used to make freehand georeferenced
edits in the field which can then be imported into ArcGIS Desktop.
- ArcPad Photo Layer file (*.aph): The ArcPad Photo Layer file is an XML file that
references a folder containing georeferenced images. Images contained in the folder are
projected on-the-fly to the current map projection coordinates when displayed in ArcPad. The
ArcPad Photo Layer file supports JPEG images. The default symbol for features in this layer is
a camera.
- ArcPad Stylesheet (*.aps): An ArcPad Stylesheet is a file that provides symbol
definitions for the symbol styles used by ArcPad. ArcGIS Desktop stylesheet files can be
exported to ArcPad Stylesheet files.
