Using the Find tool to locate a place |
Release 8 |
The Find dialog box also enables you to find a location based on a set of coordinates. You can select from the following coordinate systems: the current map projection, Latitude–Longitude, the current UTM Zone, and MGRS. Simply enter the required information and ArcPad will go to the location and label it. The default label is Mark.
The Find dialog box opens.
The location is labeled on your map.
