Geocentric Coordinate System |
Release 9.3
Last modified October 21, 2008 |
Print all topics in : "Supported map projections" |
The geocentric coordinate system is not a planar coordinate system based on a map projection
. It is a geographic coordinate system in which the earth is modeled as a sphere or spheroid in a right-handed X,Y,Z system measured from the center of the earth.
The X-axis points to the prime meridian, the Y-axis points 90° away in the equatorial plane, and the Z-axis points in the direction of the North Pole.
A geocentric coordinate system is similar to a geographic coordinate system based on latitude and longitude, which measures angles from the earth's center.
The geocentric coordinate system is used internally as a transient system. It is used as a framework for calculations as part of several geographic (datum) transformation methods.
Learn more about geographic transformation methods
