About setting distance units |
Release 9.1
Last modified January 25, 2006 |
Print all topics in : "Creating new features" |
Sometimes when creating features using the editing tools in ArcMap you need to enter data that was recorded in different distance units than the coordinate system of your data.
For example, suppose your data is in a State Plane coordinate system and the linear units are U.S. Survey Feet (1 Foot_US = 0.3048006096 m). You are given measurements in international feet (1 Foot = 0.3048 m). Rather than convert all the measurements, you can type the abbreviation for International Foot, "ft", after the measurements and the tools will convert the distance correctly. You could also change the dataset coordinate system definition to use International Feet and type the distances without a unit suffix.
Whenever you are typing a distance into one of the editing tools, you have the option to specify the linear units or simply type a number, which the tool will interpret as being in the dataset's coordinate system units. Distance unit abbreviations won't work, however, if your data frame is not projected—in other words, if your data frame is not using a projected coordinate system.
The following sections outline all the distance units supported in ArcMap and describe how to implement them.
| Distance units | Abbreviation | Meters per unit | Description |
| Kilometer | km | 1000 | 1,000 meters exactly |
| Meter | m | 1 | International meter |
| Centimeter | cm | .01 | 1/100 meter exactly |
| Millimeter | mm | 0.001 | 1/1000 meter exactly |
| Foot | ft | 0.3048 | Standard foot used in the U.S. Also known as international foot or imperial foot that was used in most nonU.S. countries before the metric system. |
| Mile | mi | 1609.344 | Also referred to as a statute mile, equal to 5280 international feet. |
| Nautical
mile |
nm | 1852 | The nautical mile is a unit of distance used primarily in sea and aviation. The nautical mile is defined as the average distance on the earth's surface represented by one minute of latitude. In 1929, the nautical mile was defined as exactly 1852 meters, or 6076.11549 feet, a distance known as the international nautical mile. |
| Chain | ch | 20.1168 | 66 international feet |
| Yard | yd | 0.9144 | Three international feet |
| Rod | rd | 5.0292 | 1/4 chain, or 16.5 international feet |
| Link | lk | 0.201168 | 1/100 international chain, or 66/100 international feet |
| Inch | in | 0.0254 | 1/12 international foot |
| Survey
foot |
ftUS | 0.3048006096 | The U.S. survey foot is used in the State Plane Coordinate Systems. In the U.S., fundamental survey units such as rods, chains, statute miles, acres, sections, and townships all depend on the U.S. survey foot. An exact conversion to meters can be accomplished by multiplying U.S. survey feet by the fraction 1200/3937. |
| Survey
mile |
miUS | 1609.3472186944 | 5280 survey feet |
| Survey
chain |
chUS | 20.1168402337 | 66 survey feet |
| Survey
rod |
rdUS | 5.0292100584 | 1/4 survey chain |
| Survey
link |
lkUS | 0.2011684023 | 1/100 survey chain |
| Survey
yard |
ydUS | 0.9144018288 | 3 survey feet |
You can use conversion constants to convert from one measurement system to another. The measurement system to be converted should be multiplied by the associated conversion constant. For example, to convert feet to centimeters, multiply feet by the conversion constant of 30.48 (27 feet x 30.48 = 822.96 centimeters).
View a table of conversion constants
To view this document, you need a copy of Adobe Reader, which you can download free from http://www.adobe.com/products/acrobat/readstep.html.
