Collect Events with Rendering (Spatial Statistics) |
Release 9.2
Last modified January 9, 2009 |
Converts event data to weighted point data and applies a graduated circle rendering to the count field.
Illustration
Usage tips
The Collect Events Rendered model combines the functions Collect Events and Count Rendering.
This tool will only work on the windows operating system. If you are not using windows, please run the Collect Events tool by itself.
The environment settings do not affect this tool.
Command line syntax
An overview of the Command Line window
CollectEventsRendered_stats <Input_Incident_Features> <Output_Layer_File> <Output_Weighted_Point_Feature_Class>
| Parameter | Explanation | Data Type |
| <Input_Incident_Features> |
The features representing event or incident data. |
Feature Class |
| <Output_Layer_File> |
The layer file to store the graduate circle rendering information. You must include the .lyr extension as part of the file name. |
Layer File |
| <Output_Weighted_Point_Feature_Class> |
The output feature class to contain the weighted point data. |
Feature Class |
workspace e:\project93\data CollectEventsRendered assaults.shp assaults_weight.shp assaults
Scripting syntax
About getting started with writing geoprocessing scripts
CollectEventsRendered_stats (Input_Incident_Features, Output_Layer_File, Output_Weighted_Point_Feature_Class)
| Input_Incident_Features (Required) |
Feature Class |
| Output_Layer_File (Required) |
Layer File |
| Output_Weighted_Point_Feature_Class (Required) |
Feature Class |
# Convert input data to weighted point data and render
# Import system modules
import arcgisscripting, sys, string, os
# Create the Geoprocessor object
gp = arcgisscripting.create()
# Local variables...
workspace = "c:/project93/data"
input = "coffeestar.shp"
input_weighted = "star_weight.shp"
weighted_rendered = "weighted_rendered.lyr"
try:
# Set the workspace (to avoid having to type in the full path to the data every time)
gp.Workspace = workspace
# Process: Collect Events with Rendering...
gp.CollectEventsRendered_stats(input, input_weighted, weighted_rendered)
except:
# If an error occurred while running a tool, print the messages
print gp.GetMessages()
Model
| Element | Explanation |
| Collect Events |
Finds all features at the same location and counts them. Creates a new feature class that has a feature at this location with the count as an attribute. |
| Count Rendering |
Renders features with a hot to cold color scheme based on an input count field. |
