Erase (Analysis) (ArcInfo only) |
Release 9.2
Last modified January 13, 2009 |
Print all topics in : "Tools" |
Creates a feature class by overlaying the Input Features with the polygons of the Erase Features. Only those portions of the Input Features falling outside the Erase Features outside boundaries are copied to the Output Feature Class.
Learn more about how Erase works
Illustration
Usage tips
Input Feature polygons that are coincident with Erase Feature polygons will be removed.
The Erase Features must be polygons.
Output may be multipart. If multipart features are not desired, use the Multipart to Singlepart tool on the output.
When processing datasets that contain any individual feature with a very large number of vertices (e.g., hundreds of thousands to millions of vertices within a single feature), some geometric processing operations may run out of memory. For more details, see Geoprocessing with large datasets.
The following environment settings affect this tool: Coordinate system, Extent, XY Tolerance, Z Tolerance, M Tolerance, XY Resolution, Z Resolution, M Resolution, Output XY domain, Output Z domain, Output M domain, Output has M values, Output has Z values, Default Z value, Configuration keyword, Output Spatial Grid.
Command line syntax
An overview of the Command Line window
Erase_analysis <in_features> <erase_features> <out_feature_class> {cluster_tolerance}
| Parameter | Explanation | Data Type |
| <in_features> |
The input feature class or layer. |
Feature Layer |
| <erase_features> |
The features whose outer polygon defines the erasing area. |
Feature Layer |
| <out_feature_class> |
The feature class that will contain only those Input Features that lie outside the Erase Features area. |
Feature Class |
| {cluster_tolerance} |
The minimum distance separating all feature coordinates (nodes and vertices) as well as the distance a coordinate can move in X or Y (or both). You can set the value to be higher for data that has less coordinate accuracy and lower for datasets with extremely high accuracy. |
Linear unit |
erase_analysis d:\ workspace\vegetation.shp d:\workspace\fire_poly.shp d:\new_workspace\no_damage.shp 1.3
Scripting syntax
About getting started with writing geoprocessing scripts
Erase_analysis (in_features, erase_features, out_feature_class, cluster_tolerance)
| in_features (Required) |
Feature Layer |
| erase_features (Required) |
Feature Layer |
| out_feature_class (Required) |
Feature Class |
| cluster_tolerance (Optional) |
Linear unit |
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:/test_data"
gp.toolbox = "analysis"
gp.erase("vegetation.shp", "fire_poly.shp", "no_damage.shp", "1.3")
