TIN Compare (Data Management) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Compares two TINs and returns the comparison results. TIN Compare can report differences with geometry, TIN node and triangle tags, and spatial reference.
Usage tips
The tool returns messages showing the comparison result. By default the tool will stop executing after encountering the first miscompare. To report all differences, set the continue compare option to true.
The Output Compare File will contain all similarities and differences between the Input Base Features and the Input Test Features. This file is a comma delimited text file which can be viewed and used as a table in ArcGIS. For example, this table can be queried to obtain all the ObjectID values for all the rows that are different.
Command line syntax
An overview of the Command Line window
TINCompare_management <in_base_tin> <in_test_tin> {ALL | PROPERTIES_ONLY | SPATIAL_REFERENCE_ONLY} {NO_CONTINUE_COMPARE | CONTINUE_COMPARE} {out_compare_file}
| Parameter | Explanation | Data Type |
| <in_base_tin> |
The Input Base Tin is compared with the Input Test Tin. Input Base Tin refers to your data that you have declared valid. This base data has the correct geometry, tag values (if any), and spatial reference. |
Tin Layer |
| <in_test_tin> |
The Input Test Tin is compared against the Input Base Tin. |
Tin Layer |
| {ALL | PROPERTIES_ONLY | SPATIAL_REFERENCE_ONLY} |
The comparison type.
String |
| {NO_CONTINUE_COMPARE | CONTINUE_COMPARE} |
Indicates whether to compare all properties after encountering the first mismatch.
Boolean |
| {out_compare_file} |
The name and path of the text file which will contain the comparison results. |
File |
TINCompare_management c:\workspace\basetin c:\workspace\newtin ALL CONTINUE_COMPARE C:\workspace\tincompare.txt
Scripting syntax
About getting started with writing geoprocessing scripts
TINCompare_management (in_base_tin, in_test_tin, compare_type, continue_compare, out_compare_file)
| in_base_tin (Required) |
Tin Layer |
| in_test_tin (Required) |
Tin Layer |
| compare_type (Optional) |
String |
| continue_compare (Optional) |
Boolean |
| out_compare_file (Optional) |
File |
# TinCompare.py
# Description: Compare two TINs and return comparison result.
# Requirements: None
# Author: ESRI
# Date: 11/16/05
# Create the Geoprocessing Object
import arcgisscripting, sys, os
gp = arcgisscripting.create()
try:
# Set local variables
base_tin= "C:/Workspace/basetin"
test_tin= "C:/Workspace/newtin"
compare_type = "ALL"
continue_compare = "CONTINUE_COMPARE"
compare_file = "C:/Workspace/tincompare.txt"
# Process: TinCompare
compare_result = gp.TinCompare_management(base_tin, test_tin, compare_type, continue_compare, compare_file)
print compare_result
print gp.GetMessages()
except:
# Print error message if an error occurs
