Compact (Data Management) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Compacts a file or personal or file geodatabase. Compacting rearranges how the database is stored on disk, often reducing its size and improving performance.
Usage tips
You should compact your databases on a regular basis if you do a lot of data entry and deletion.
Personal and file geodatabases are stored in binary files on your disk drive. As you add/remove/edit data in these files they will become fragmented, resulting in a decrease in performance.
It is recommended that you compact your Personal Geodatabase when its size increases to more than 250 MB.
If a database is opened in ArcMap for editing, it cannot be compacted. To compact the database, remove it from ArcMap.
The following environment settings affect this tool: workspace, scratch workspace, and Configuration keyword.
Command line syntax
An overview of the Command Line window
Compact_management <in_workspace>
| Parameter | Explanation | Data Type |
| <in_workspace> |
The file or personal geodatabase to be compacted. |
Workspace |
compact_management d:\landuse.mdb
Scripting syntax
About getting started with writing geoprocessing scripts
Compact_management (in_workspace)
| in_workspace (Required) |
Workspace |
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.toolbox = "management"
gp.compact("d:\landuse.mdb")
