Check In (Data Management) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Synchronizes changes from a check-out replica in an ArcSDE, file, or personal geodatabase to the parent ArcSDE geodatabase.
Note that this tool is designed for check-out replicas only and should only be used to support applications from earlier releases. It is recommended that you use the synchronize changes tool in place of this tool.
Usage tips
You must have permission to edit the data you are synchronizing.
Once synchronized, the changes (edits) will be reflected in the parent geodatabase and are viewable by all users.
Data cannot be replicated with ArcView.
The following environment settings affect this tool: workspace, scratch workspace, and Configuration keyword.
Command line syntax
An overview of the Command Line window
Checkin_management <in_workspace> <dest_workspace> {NON_RECONCILE | RECONCILE}
| Parameter | Explanation | Data Type |
| <in_workspace> |
The child replica geodatabase. The workspace that contains the child replica. This can be an ArcSDE, file, or personal geodatabase. |
Workspace |
| <dest_workspace> |
The parent replica geodatabase. The ArcSDE workspace to which changes will be applied. |
Workspace |
| {NON_RECONCILE | RECONCILE} |
Indicates whether the synchronization process should reconcile the synchronization version after the edits have been synchronized.
Boolean |
CheckIn_management d:\workspace.mdb "Database Connections\Connection to workspace.sde" NO_RECONCILE
Scripting syntax
About getting started with writing geoprocessing scripts
Checkin_management (in_workspace, dest_workspace, reconcile)
| in_workspace (Required) |
Workspace |
| dest_workspace (Required) |
Workspace |
| reconcile (Optional) |
Boolean |
import arcgisscripting
gp = arcgisscripting.create()
gp.toolbox = "management"
gp.CheckIn("d:\workspace.mdb", "Database Connections\Connection to workspace.sde", "NO_RECONCILE")
