Check In from Delta (Data Management) (ArcInfo and ArcEditor only) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Imports changes from a delta file into the parent replica. A delta file contains only the changes exported from a child replica geodatabase.
Note that this tool is designed for check-out replicas only and should only be used to support applications from earlier releases. It is recommended that you use the import message tool in place of this tool.
Usage tips
Instead of synchronizing edits directly from the child replica geodatabase, you can export the changes only from the child replica to a delta file. Delta files are smaller than the original child replica geodatabase.
When the synchronize from a delta file succeeds, the check-out replica in the parent geodatabase is unregistered.
Synchronizing changes from a delta file does not automatically unregister the replica in the child replica geodatabase; this must be done manually.
The following environment settings affect this tool: workspace, scratch workspace, and Configuration keyword.
Command line syntax
An overview of the Command Line window
CheckinDelta_management <in_delta_database> <dest_workspace> {NON_RECONCILE | RECONCILE}
| Parameter | Explanation | Data Type |
| <in_delta_database> |
The delta file that contains the changes to be synchronized. |
File |
| <dest_workspace> |
The parent replica geodatabase. The ArcSDE workspace to which changes will be applied. |
Workspace |
| {NON_RECONCILE | RECONCILE} |
Indicates whether the synchronize process should reconcile the synchronization version after the edits have been synchronized.
Boolean |
CheckInDelta_management c:\data\housing.mdb "Database Connections\Connection to workspace.sde" NO_RECONCILE
Scripting syntax
About getting started with writing geoprocessing scripts
CheckinDelta_management (in_delta_database, dest_workspace, reconcile)
| in_delta_database (Required) |
File |
| dest_workspace (Required) |
Workspace |
| reconcile (Optional) |
Boolean |
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:/test_data"
gp.toolbox = "management"
gp.checkindelta("housing.mdb", "Database Connections\Connection to workspace.sde", NO_RECONCILE)
