Set Cluster Tolerance (Data Management) (ArcInfo and ArcEditor only) |
Release 9.2
Last modified November 29, 2010 |
Print all topics in : "Tools" |
Alters the cluster tolerance for the Input Topology. The cluster tolerance is used when validating the topology.
Usage tips
You cannot alter the cluster tolerance for a topology if the topology has been registered as versioned.
Changing the cluster tolerance will require the entire topology be validated.
For more information about cluster tolerance, see the Cluster Tolerance Environment and the Cluster Tolerance topic in the Topology Basics Help.
The following environment affects this tool: Workspace, scratch workspace, cluster tolerance, and extent.
Command line syntax
An overview of the Command Line window
SetClusterTolerance_management <in_topology> <cluster_tolerance>
| Parameter | Explanation | Data Type |
| <in_topology> |
The topology for which you want to change the cluster tolerance. |
Topology |
| <cluster_tolerance> |
The minimum distance between vertices in the topology. Vertices that fall within the cluster tolerance will be snapped together during the validate topology process. If you enter a value of zero, the default or minimum cluster tolerance will be applied to the topology. |
Double |
SetClusterTolerance D:\Calgary\Trans.mdb\Streets\Street_Topo 0.00015
Scripting syntax
About getting started with writing geoprocessing scripts
SetClusterTolerance_management (in_topology, cluster_tolerance)
| in_topology (Required) |
Topology |
| cluster_tolerance (Required) |
Double |
